kyteler
Beaver's '87 Gloria Wagon
175 posts in this topic
@kyteler tried to PM you but it wouldn't work, but rekon you could grab that cam when you are up to it? Would be mucho appreciated.
1 person likes this
Share this post
Link to post
Shit yes, buy some spats
Go full JAP custom
Share this post
Link to post
Hey boover, I have a 71C bellhousing you could test with.
I like your motivation/direction
Share this post
Link to post
I have no idea what a 71C gearbox is but keen to see if it fits.
Share this post
Link to post
it's a designation used across all Nissan boxes (it's to do with ratios, etc. the 'C' stands for Close the other option is W at the end.  Guess what that stands for).  lerl.  I assume he means one for an RB though.  Not that it would matter cause an L bell should work also.
Share this post
Link to post
Monster Garage Factoid - the 71 stands for 71mm between centres of the main and lay shaft in the gearbox.
(just like the 63 in 63a means it is 63mm from centre to centre)
5 people like this
Share this post
Link to post
I likely knew that at some point but now I do again, thank-you Kesse Kames.
Share this post
Link to post
Wink.. Boyd Kytelerton
1 person likes this
Share this post
Link to post
Sorry, was being lazy, I mean I have a bellhousing for a FS5W71C box which can be found on some RB's Silvias etc
Also have a FS5W71B box with poo synchros
The deez bellhousing i have can be swapped straight onto the 71C and lets you bolt it up to L series
Enough ramblings, I should do something with my gearbox bits one day.
Share this post
Link to post
Oh mean, keen to grab it from you and see if it will bolt up.
Share this post
Link to post
We can see if our parts dock nicely
3 people like this
Share this post
Link to post
FS5W71C
Floor Shift
5 speed
Warner synchros
71mm between shafts centers
C revision box. (Larger countershaft front bearing, larger 1st/2nd synchros+ selector)
R4W71B
Remote (column)
4 speeds
B revision.
Etc
FS5C71B
Same but the C stands for Porsche type steel servos(synchros)
I have found these in random zed's but in no particular pattern.
RFB twenny debt and 25 no debt and s13/14 have the C type box with the 6 bolt plate at the back holding the shifter.
The bellhousings are mostly interchangeable. If you try to run a C onwards gearset in a B housing you will need to machine a bit of clearance for the larger counter gear and bearing, and drill out the 1st/2nd selector rod hole from 14 to 16mm.
The B gearset goes straight into the C housing with the C bearing, but you need to sleeve the selector hole down to 14mm.
The gearbox revisions went all the way to H. The later ones had synchros on reverse and double synchros on 2nd.
I have a good selection of boxes, parts, new synchros etc in stock if you need bits.
Barry out...
3 people like this
Share this post
Link to post
Lol.
i only need it to bolt up a starter motor
Share this post
Link to post
19 minutes ago, Beaver said:
Lol.
Haha didn't see that.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
