I know with Toyota there are multiple options usually and some are better suited than others, situation / usage dependant. More info will lead to the best answers. Unless there is literally only one manual gearbag that will work in a sigma. I'd be surprised though.
Could be weak gearbags worth avoiding, shit ratios, fitment issues and that sort of thing.
It’s for a 84 sigma gsrx 2ltr auto obviously I don’t no jak about this sort of thing lol just looking for advice cheers
You are going to need to say what you want to achieve
Bolt in I guess if you don't know much
Asking for advice? That will get you - It's a mitsi, scrap it
Getting it converted to manual I no I Probably won’t find another sigmas for parts what other car gear box will fit or options?
Is it front wheel drive or rear wheel drive?
You will need:(off the top of my head)
Clutch cable (may be available new)
Pedal box
Cross member
Clutch (available new)
Crossmember
Gearbox -probably narrow block, so sigma or early l200, l200 has different output shaft
Driveshaft with yoke to suit gearbox
Cert
Pedal box
Cross member
Crossmember
Cert
Front wheel drive cheers thank you
Another thing worth noting, is that if you replace the current brake pedal with another, it will need a cert. Changing the pedal box from auto to manual parts triggers this requirement (brake pedal specifically). This is technically of course, lots of auto to manual swaps running around which need cert but will likely not be picked up. Just something worth knowing before carrying on.
Easy answer is to just live the easy life with the auto, they aren't that bad.
Cheers thank you
I assume you are buying/have bought the white GSR-X on trademe.
I have just completed a manual conversion on my FWD Sigma, but I luckily had a donor car to get all the bits I needed.
If I was to do it again I would look to use a gearbox from a SB/SC/E33A Galant. These gearboxes dont use a vacuum actuator to select 5th gear. Its all cables. Make sure to get the selector cables to suit that gearbox. For the clutch pedal I think you will need one from a manual Sigma as I dont think the Galant is the same. Pretty sure axles are the same between auto and manual.
