SOHC Posted August 12, 2022 Author Posted August 12, 2022 New frame, its good apart from center stand threads 3 Quote
SOHC Posted August 21, 2022 Author Posted August 21, 2022 The down tube on the front of the frame had a budge in it about 20mm,managed to pull it back, also it was off to one side by about 20mm, got that good to, I will have to do some more measurements and see if its not bent anywhere elce. 5 Quote
SOHC Posted August 28, 2022 Author Posted August 28, 2022 Forks have new bronze bushes and seals, and fitted to the new frame, 8 Quote
SOHC Posted October 20, 2022 Author Posted October 20, 2022 Started on the engine plates, I still need to find a magneto platform so I can trim the plates behind the engine to the right height to support the magneto, I have made the plates from 1/4" nice and solid. 6 Quote
SOHC Posted October 20, 2022 Author Posted October 20, 2022 Got this magneto someone has gutted and jammed a distrubtor in it. 2 Quote
SOHC Posted October 20, 2022 Author Posted October 20, 2022 I am thinking of using it to support the bearings to mount this tiny unit witch would take care of spark and charging, it would cost around $2000 or more to get an original magdyno and have it rebult. 3 Quote
GregT Posted October 21, 2022 Posted October 21, 2022 I'm told it's common with mag sparked classic race cars - Ferraris etc - to use the mag or mags as a distributor for coil ignition. Finding someone to rebuild even 50's multi cylinder race mags is getting very hard. Guy I know down here has stopped doing them now. He showed me a mag he'd rebuilt for a RR Phantom which was doing the Peking - Paris. 12 Cylinder Bosch. It apparently never missed a beat Last bike one he did was a Lucas for a Rudge I was building. What's the alternator from ? There are some very small ones now on small agricultural diesels. 1 Quote
Raizer Posted October 21, 2022 Posted October 21, 2022 46 minutes ago, GregT said: What's the alternator from ? There are some very small ones now on small agricultural diesels. Looks to be pit bike style. 1 Quote
SOHC Posted October 21, 2022 Author Posted October 21, 2022 1 hour ago, GregT said: I'm told it's common with mag sparked classic race cars - Ferraris etc - to use the mag or mags as a distributor for coil ignition. Finding someone to rebuild even 50's multi cylinder race mags is getting very hard. Guy I know down here has stopped doing them now. He showed me a mag he'd rebuilt for a RR Phantom which was doing the Peking - Paris. 12 Cylinder Bosch. It apparently never missed a beat Last bike one he did was a Lucas for a Rudge I was building. What's the alternator from ? There are some very small ones now on small agricultural diesels. Some mags can still be good at 90 years old, but could fail at any time, I killed one on my B31 I recon from the lead falling off at full trottel, rebuild cost $1200 from the Maddocks, armature, was sent to Australia. That little alternator/ ignition is from a Lifan 125, it has 3 lighting coils and a source coil and a pick up for the CDI, I will make it so I can retard it from the handelbar control 1 Quote
tortron Posted October 21, 2022 Posted October 21, 2022 10 hours ago, Raizer said: Looks to be pit bike style. People swap them into dr125s for light flywheel race action. Basically a GN125 part 2 Quote
SOHC Posted October 22, 2022 Author Posted October 22, 2022 Is there some bearing that could support that flywheel with the small sprocket on the other side? Then I dont have to use that mag body and I can tuck the flywheel ignition right behind the cylinder Quote
Goat Posted October 24, 2022 Posted October 24, 2022 I've got a spare magdyno for sale if you'd like to go that route. Clockwise mag direction. Tapered shaft. Was sparking and dynomo-ing last I checked. 2 Quote
tortron Posted October 24, 2022 Posted October 24, 2022 On 22/10/2022 at 21:34, SOHC said: Is there some bearing that could support that flywheel with the small sprocket on the other side? Then I dont have to use that mag body and I can tuck the flywheel ignition right behind the cylinder You could use half a GN125 crank Quote
SOHC Posted October 24, 2022 Author Posted October 24, 2022 1 minute ago, tortron said: You could use half a GN125 crank I was thinking about doing that to get the tapper and keyway and thread, I cant use a lathe like that even tho i have one. Quote
tortron Posted October 24, 2022 Posted October 24, 2022 Il swap you one for a little aluminium repair 1 Quote
SOHC Posted November 2, 2022 Author Posted November 2, 2022 Got some old tires from a friend's place, fitted new rim tapes and tubes, this will get it on its wheels to finish the mudgaurd stays, I will get new tires at another stage, front tire is a race tire so will probably be extra dodgy. 3 Quote
SOHC Posted November 9, 2022 Author Posted November 9, 2022 Got the guards mounted, they are old bits of shit I found, stays are recycled junkcut and welded I, made sure everything has heaps of super stud lock on it and is straight and its good to go, that rear number plate/ light thing is off a Bantam, I choped it down, I might invest in a can of paint to touch up hear and there, I want to fuck up the chrome on the tank some how, I think you can do it with some acid and a rag and a car battery. 3 Quote
SOHC Posted November 10, 2022 Author Posted November 10, 2022 Made a center stand, this afternoon. 6 Quote
Popular Post SOHC Posted November 11, 2022 Author Popular Post Posted November 11, 2022 Got this magdyno from Goat, it has spark, I put a different cover on it and may take it apart and clean / lube it, I now have everything for the engine. 10 Quote
SOHC Posted November 29, 2022 Author Posted November 29, 2022 Almost finished the rear engine plates, still need to file out the slots for the mag platform, for some reason the oil tank doesn't fit now and would need spacing out, I have to make an adapter for the carburetor spigotthat has a 45 degree angle on it or shorten it drastically. 5 Quote
