discuss large golden vehicle
just keeping it pretty much stock, probably with more low
maybe this look?
although I love this,
pic taken from os somewhere ^
50 minutes ago, chris r said:
Fuck yes. Hopefully you have it ready for drags and we can have 202 battles
It'll be ready, this is just extra motivation!
1 hour ago, nzstato said:
Choice!
Having been there, draining the tanks on these are a bit of a prick...
Was assessing the job today and decided to leave it for another time. Seems to be a bit involved but I should really do it, the fuel pump bowl is some orange/yellow colour :(
Cheers @Kiwibirdman for sorting me out with some wide steelies. These will be perfect for my wagon. Getting a balance tomorrow and that's the wheels sorted! Mint.
He also sorted me out with a new 3 core V8 rad for next years motor swapping endeavor.
Little something for next year.
sbc 350.
I'll grab a 4L60 trans I'm thinking, for overdriveness/keep revs down on the motorways etc?
I'd like to keep the column change.
th700/ 4L60 ex vn vp commy or an 80s camaro fit quite well  , iv got a built th700 behind an ls1 in my HQ sedan all hooked up to the factory column shift using a b&m cable able to  get the full shift travel down to 1st I had to  clearance for larger billet servo housing but not by much,  just chopped up a factory crossmember to suit, running a 3.55 diff sits about 2200rpm  at 100k
5 hours ago, Kiwibirdman said:
For connecting the TH400 to the column shift use a cable as above. The factory cross over is almost impossible to get and really complicated.
This will have to be the go. I suppose I'll just have to make a bracket to mount the cable to the firewall and get a bracket to suit the TH on the other end, thinking it won't be a hard task all going well. It's all metal and all basic so I should be sweet.
I even have the gas pedal with the kickdown switch to suit so things are moving quickly.
Thank you Kumehu!
4 and a half hours of walking through a paddock landed me with a cheap TH400 and converter, which happened to be the only one at the entire swapmeet, 5 Qjet carbs, and some early 327 steel valve covers I had been looking for. Even grabbed 2 new mufflers while I was there.
With the TH400 I'm now able to get my motor on the ground and start getting things together. I'll floor start the motor soon I'm thinking.
I also need to clean up my diff and get that ready to go. Then the only hold-ups ill have will be with throttle cable and shift linkage setup. Other than that I'm hoping the swap can be done in a short amount of time.
