Dudley Posted May 22, 2020 Posted May 22, 2020 Is there any Toyota strut that will bolt into a ke20 and raise the ride height but still allow me to retain factory brakes/hubs ? o 3 1 Quote
ajg193 Posted May 22, 2020 Posted May 22, 2020 Looks like you already have 2 feet of ground clearance 1 Quote
kpr Posted May 22, 2020 Posted May 22, 2020 / anyone got some OG struts that haven't had the guts replaced with an insert? dodgy re-valve plus weld on schrader valve for that nitro compressed air charge @Dudley wants to give you money for them Quote
cletus Posted May 22, 2020 Posted May 22, 2020 Just now, kpr said: plus weld on schrader valve for that nitro compressed air charge I wonder if you did that and put some diesel in the shock and sealed up the shock valving , and do a jump Would you get a really good rebound? 6 1 Quote
Beaver Posted May 22, 2020 Posted May 22, 2020 10 hours ago, UTERUS said: This sounds like a job for strut spacers. This guy knows what's up. Quote
kpr Posted May 23, 2020 Posted May 23, 2020 1 minute ago, cletus said: I wonder if you did that and put some diesel in the shock and sealed up the shock valving , and do a jump Would you get a really good rebound? maybe put some oxy in instead of nitrogen. bit more travel would be nice. but some more compression damping while retaining the lack of rebound should make it fly and land like a trophy truck. Its borderline that already, so with some minor tweaks... 2 Quote
kpr Posted June 3, 2020 Posted June 3, 2020 Turns out it still had the og shocks in the struts. pulled one of them apart. found they have a stopper on shaft to limit extension travel. chopped that off and welded it back on 40mm lower. did some super janky shaft re-polish. they were leaky anyway so whats a bit more. also "machined" the little spacer plate on compression side of shocks. to effectively make bleed holes on compression side smaller. so will have who knows how much more compression dampening, along with 40mm more droop for those hectic jumps. I want to add a second shock on the rear that only starts working at last 1/3 or so travel. so its like some kinda amazing redneck hillbilly bypass shock 2 Quote
cletus Posted June 3, 2020 Posted June 3, 2020 On 23/05/2020 at 12:15, Dudley said: @cletus this will past cert aye? A long as you used high tensile welding gas that will be fine 3 2 Quote
Dudley Posted June 3, 2020 Author Posted June 3, 2020 Cool when can we book it in? I assume working brakes won’t be necessary ? 1 Quote
Dudley Posted June 3, 2020 Author Posted June 3, 2020 8 hours ago, kpr said: Turns out it still had the og shocks in the struts. pulled one of them apart. found they have a stopper on shaft to limit extension travel. chopped that off and welded it back on 40mm lower. did some super janky shaft re-polish. they were leaky anyway so whats a bit more. also "machined" the little spacer plate on compression side of shocks. to effectively make bleed holes on compression side smaller. so will have who knows how much more compression dampening, along with 40mm more droop for those hectic jumps. I want to add a second shock on the rear that only starts working at last 1/3 or so travel. so its like some kinda amazing redneck hillbilly bypass shock Looks like player two has entered the game with space x on launching gc to the moon..... 1 1 Quote
