bonkas Posted September 10, 2017 Share Posted September 10, 2017 Constructive chat and/or criticism goes here. Here is the Build Thread: Quote Link to comment Share on other sites More sharing options...
bonkas Posted September 10, 2017 Author Share Posted September 10, 2017 What Fuel pumps do you guys run with your carbs? I am wanting to delete the Mech Fuel pump and change to electric. These carbs require 1.5-3PSI and I want to make use of the return on the car also. Looking at something like this: https://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-1406301219.htm but unsure whether this regulator contains a return... If you guys have any recommendations that will be much appreciated. Quote Link to comment Share on other sites More sharing options...
azzurro Posted September 11, 2017 Share Posted September 11, 2017 I dont know anything about them but just reading the specs that blue seems like it might be a bit much, you might need to crank the regulator down so much (its a restriction) from the max (14psi) to get near to the ideal 3psi max for your carbs you might be better getting a pump with lower pressure for better flow. (You would also need a seperate pressure gauge to know what you are setting it at). Pretty sure Holley does a specific low pressure carb pump Those box facet style pumps are fine on my set up (i have a malpassi filter king regulator), but other than the twin carbs its pretty close to std. You could go full retard and have your tank setup for future EFI, and just have the mechanical pump draw from the surge tank for now? Quote Link to comment Share on other sites More sharing options...
bonkas Posted September 11, 2017 Author Share Posted September 11, 2017 Something like this is very attractive given it's price! and supposedly NZ Made: https://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-1410359255.htm 015L Low Pressure Piston Pump: 12v - up to 2500cc, 1.5L/M, 2psi It gives 2 PSI which is withen the 1.5-3 PSI (3.5 MAX) Dellorto Advise It also supplies 2L/min and dellorto specify between 1-2 L/min for 1-2.5L of engine capacity. Is something like that pump something to stay away from? Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted September 11, 2017 Share Posted September 11, 2017 Someone just installed one of those. It was ragtop in the bug. Quote Link to comment Share on other sites More sharing options...
bonkas Posted September 11, 2017 Author Share Posted September 11, 2017 What are your thoughts on this pump @63Ragtop? Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted September 11, 2017 Share Posted September 11, 2017 Oi, how did I end up in here? That is the model I got, seems okay so far, will know for sure once I get the engine running better, seemed fine for the time it was running. But the pump its self works well, quite, self primes, doesn't seem to over power the floats like the 044 I tried out. Quote Link to comment Share on other sites More sharing options...
bonkas Posted September 11, 2017 Author Share Posted September 11, 2017 Did you incorporate a fuel return in your build? Will it harm anything just to block this off? Quote Link to comment Share on other sites More sharing options...
bonkas Posted September 15, 2017 Author Share Posted September 15, 2017 Few more thoughts ive had of this build... 1. Vacuum - Has anyone had any vacuum issues with twin side draft carbs? I hear horror stories but wondering what your experiences have been? I am wanting to hook up the vacuum for the brake assist. 2. Distributor Timing - Are they any old school guys still around who can do some magic on distributors? I have a no-points dizzy and may need to increase or statically set the advance, or maybe I can get away with leaving as is with vacuum advance (Carbs have a vacuum progression port for vacuum advance). Quote Link to comment Share on other sites More sharing options...
bonkas Posted November 20, 2017 Author Share Posted November 20, 2017 Have had a wee setback, have received the pistons but they do not have the 10cc dome I had asked for, only 7cc which means the compression ratio I was shooting for will not be correct so further decking of the block and modifying of the pistons is required (deck block, machine pistons to suit and smooth out the dome and valve pockets for better flow and to prevent hot spots. All of this would have been avoided if the pistons were correct. This was mis-communication between myself, the agent and the manufacturer and I am unsure where I stand in regards to hitting up the piston agent. I had asked for a 10cc dome which they had done BEFORE cutting the valve pockets so this has left me with 7cc overall. Bit of a discussion of this over here: New valves have arrived and seats are being cut this week and cam is being sorted as we speak so hopefully the head will be back with me this week or next and I can start work on manifolds, pistons and block work (balancing, decking etc). Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 3, 2017 Author Share Posted December 3, 2017 Small update while I wait for my head and cam to come back. Sending headers I rescued from doner car in to get cleaned up. What is the best coating to put on these? Also going to source new uprated clutch and have flywheel lightened. Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 7, 2017 Author Share Posted December 7, 2017 Have given a whole new lease of life to these headers. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 10, 2018 Share Posted February 10, 2018 You bought an oil pump sprocket for a DOHC engine that has a wider timing belt... 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted May 21, 2018 Share Posted May 21, 2018 Before you crack on with the die grinder on the inlet do some Google work searching 'anti reversion step'. I'll let you make up your own mind. Quote Link to comment Share on other sites More sharing options...
MaxPower Posted February 24, 2019 Share Posted February 24, 2019 if its of interest i have a full brand new exhaust system for a ex lancer, think its 2 1\2" system Quote Link to comment Share on other sites More sharing options...
fletch Posted February 24, 2019 Share Posted February 24, 2019 You will need that water return to allow water to circulate while it warms up before the thermostat opens. Otherwise you will get hot spots where the water will boil 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted February 24, 2019 Share Posted February 24, 2019 +1 to that After all this effort please dont cook the head gasket or whatever, for sake of a water line! Quote Link to comment Share on other sites More sharing options...
bonkas Posted February 25, 2019 Author Share Posted February 25, 2019 @Roman @fletch Yeah, I have been trying to make this happen to get the water return line but dad isnt having it, thinks it's not needed. He's the kinda guy where his word is law and im having trouble changing his mind. I think I will plumb the heater line into a tee so it splits off to the return also. @MaxPower thanks for the offier, we will be building a 2.25" system from scratch. Quote Link to comment Share on other sites More sharing options...
fletch Posted February 26, 2019 Share Posted February 26, 2019 Drill a hole in ya thermostat so it can flow during warm up and don't tell ya old man? Quote Link to comment Share on other sites More sharing options...
bonkas Posted March 3, 2019 Author Share Posted March 3, 2019 @fletchHaha he seemed to have changed his mind overnight, I have tee'd off the water to the heater so it flows back to the return when the heater is closed. Water is all plumbed up now! I got to get another fuel pump (which is on the way) as the old one had no flares on the fittings and the fuel hose slides off to easily. Quote Link to comment Share on other sites More sharing options...
