Tumeke Posted February 27, 2017 Share Posted February 27, 2017 Tell me stuffs for the Trumpet here. //oldschool.co.nz/index.php?/topic/55641-tumekes-25-pi-trumpet/ Trumpet Build Threads Quote Link to comment Share on other sites More sharing options...
kws Posted February 28, 2017 Share Posted February 28, 2017 Haha, so many feels for having a British car thats been "barried". Looks good, i like the minilite style wheels on it. Will follow. 1 Quote Link to comment Share on other sites More sharing options...
michaelme Posted February 28, 2017 Share Posted February 28, 2017 So would that be two spots for the show this weekend good sir? Quote Link to comment Share on other sites More sharing options...
Tumeke Posted February 28, 2017 Author Share Posted February 28, 2017 @michaelme Fraid not - Not running, and if it was, driving two cars is really hard. However if someone has a trailer we could bring it in and work on it, and get every second Barry's expert opinion as to why it's not running? @Threeonthetree 's suggestion I think! 3 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted February 28, 2017 Share Posted February 28, 2017 Yes, trailering it down would be great if a trailer could be sourced. The only way to unbarry a car is to get barrys to decode the barrying that has been done. Or just start from the beginning and check absolutely everything. But the swarm of Barrys would be lush. Imagine the sharns! 4 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted February 28, 2017 Share Posted February 28, 2017 That looks really nice. The PI seems to have a bit of bad reputation, but I'm sure there are enough Barries around to get it sorted. Always wondered how easy it would be to convert from mechanical injection to electronic these days. Quote Link to comment Share on other sites More sharing options...
kws Posted February 28, 2017 Share Posted February 28, 2017 #speeduino 1 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted February 28, 2017 Author Share Posted February 28, 2017 16 minutes ago, kws said: #speeduino Jeepers. Lots of pixies running about on circuit boards is pretty scary, that's why I have oldschool cars! I'm all about the plug and play! 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted February 28, 2017 Share Posted February 28, 2017 It's only a few sensors and some wiring. Megasquirt it for Max easiness Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted February 28, 2017 Share Posted February 28, 2017 Probably just some dodgy Lucas bit that's given up the ghost. I think the Chinese aftermarket parts are faithful reproductions made to the original standards... 1 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted February 28, 2017 Author Share Posted February 28, 2017 Just now, chris r said: It's only a few sensors and some wiring. Megasquirt it for Max easiness Sweet, @chris r can do that for me while I stick your 1 tonner back together? #deal 3 Quote Link to comment Share on other sites More sharing options...
chris r Posted February 28, 2017 Share Posted February 28, 2017 1 minute ago, Tumeke said: Sweet, @chris r can do that for me while I stick your 1 tonner back together? #deal Sounds like a deal to me 3 Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted February 28, 2017 Share Posted February 28, 2017 nice, i remember seeing this on the tard. Dont get rid of the mechanical injection, it is actually lush if set up right, unfortunately you will have to de barry that. The injection system is super easy to get your head around, i have a bunch of the old lucas manuals and can get copies if ya like. 99% of the time the problem with them is a blocked fuel filter or leaking injector seals that have caused the system to lose its prime. once you sort your spark issue out follow this process -remove all spark plugs - remove all injectors from the throttle body but still connected to metering unit, jam them all in a big glass jar or summin - jump the car to a running vehicle -crank for like 5 minutes to prime the injectors, they should all have a nice crisp fine conical spray them jam everything back in and do a phat skid 6 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted February 28, 2017 Author Share Posted February 28, 2017 3 minutes ago, BLIZZO said: nice, i remember seeing this on the tard. Dont get rid of the mechanical injection, it is actually lush if set up right, unfortunately you will have to de barry that. The injection system is super easy to get your head around, i have a bunch of the old lucas manuals and can get copies if ya like. 99% of the time the problem with them is a blocked fuel filter or leaking injector seals that have caused the system to lose its prime. once you sort your spark issue out follow this process -remove all spark plugs - remove all injectors from the throttle body but still connected to metering unit, jam them all in a big glass jar or summin - jump the car to a running vehicle -crank for like 5 minutes to prime the injectors, they should all have a nice crisp fine conical spray them jam everything back in and do a phat skid Pretty much what I had in mind, soon as I can find the sparks. I think we found them on the weekend but by that time I'd flooded her, so will pop in (maybe tonight) and see if she'll fire Not sure that the stater motor will last five minutes though - #lucasprinceofdarkness 1 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted March 2, 2017 Author Share Posted March 2, 2017 @BLIZZO Did your thing last night - got all injectors doing the spray thing. Had to blow a couple out on the compressor @ 70psi . Some how managed to smash a dizzy rotor into 4 bits. Also noticed there was another broken one in the boot. Not sure if it's cause the cap wasn't aligned properly or would this be a sign of a dodgy dizzy? Still no brum brum. @locost_bryan IS the Lucas stuff Chinese now you reckon?I have a spare dizzy cap at home to narrow that down and can flog the rotor off the Humber to see if that works. Both of which are newish from http://www.classiccarparts.co.nz/ - not sure where their Lucas stuff comes from?! Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted March 2, 2017 Share Posted March 2, 2017 unsure why dizzy would smash rotors, possibly whip it out and check that there isnt an abundance of shaft play, and yea make sure cap is sitting on properly, i have never had that problem before. Once that if you have spark and its still not doing anything it could possibly be that the metering unit has been timed incorrectly when re installed. its not hard to re time, there are good instructions in the lucas PI manuals. 1 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted March 2, 2017 Author Share Posted March 2, 2017 Yep, although also noticed from research that Haynes incorrectly published the wrong picture.... Wont be making that mistake when I do that next Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted March 2, 2017 Share Posted March 2, 2017 10 minutes ago, Tumeke said: @locost_bryan IS the Lucas stuff Chinese now you reckon?I have a spare dizzy cap at home to narrow that down and can flog the rotor off the Humber to see if that works. Both of which are newish from http://www.classiccarparts.co.nz/ - not sure where their Lucas stuff comes from?! Good question about what is genuine Lucas and what is Chinese repro. Some discussion on the Marina forum recommends http://www.distributordoctor.com/rotor_arms.html 1 Quote Link to comment Share on other sites More sharing options...
Tumeke Posted March 2, 2017 Author Share Posted March 2, 2017 12 minutes ago, locost_bryan said: Good question about what is genuine Lucas and what is Chinese repro. Some discussion on the Marina forum recommends http://www.distributordoctor.com/rotor_arms.html Red ones go faster. Goes without saying really. 2 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted March 6, 2017 Share Posted March 6, 2017 Two steps forward and one step back, eh? At least it's getting betterer... Quote Link to comment Share on other sites More sharing options...
