Raizer Posted September 20, 2017 Posted September 20, 2017 @Vintage Grumble are you able to do small belts? You likely know, but that looks to be a Toyota Prius water pump, probably the best thing to come from a Prius lol Got carb specs in your book there? Quote
kicker Posted September 20, 2017 Author Posted September 20, 2017 Good to know about the pump, was just looking at VW and BMW ones, would still prefer the stock setup if poss. The parts catalog carb specs match what I've got (i.e. 102 mj and 35 pj) but the manual, which is in Japanese has 95 for the mj (difference in petrol?) 1 Quote
Vintage Grumble Posted September 20, 2017 Posted September 20, 2017 10 hours ago, Raizer said: @Vintage Grumble are you able to do small belts? You likely know, but that looks to be a Toyota Prius water pump, probably the best thing to come from a Prius lol Got carb specs in your book there? I'll have a geeze when I get to work, I think they're an M or Z section or summin. 3 Quote
kicker Posted September 20, 2017 Author Posted September 20, 2017 You can't Beat service like that! Top man 1 Quote
Steelies Posted September 20, 2017 Posted September 20, 2017 another local belt option be John Brooks on railway ave. bizarre leanness is bizarre, raizer if crank seals are poked would the big dogg jet be enough to allow it to start? just curious. Quote
Goat Posted September 20, 2017 Posted September 20, 2017 One would expect if crank seals were that poked, to get it that lean, then it wouldnt push enough into the cylinder to run. And you'd be able to hear it leaking! Is it actually getting enough fuel Kicker? wasn't your fuel tap a bit ham? Float height? Intake Gaskets? Are these reed or piston port? Quote
MKD Posted September 20, 2017 Posted September 20, 2017 1 hour ago, Goat said: One would expect if crank seals were that poked, to get it that lean, then it wouldnt push enough into the cylinder to run. And you'd be able to hear it leaking! Is it actually getting enough fuel Kicker? wasn't your fuel tap a bit ham? Float height? Intake Gaskets? Are these reed or piston port? +1 on fuel tap/pump - my FR had fueling issues for ages and i ended up selling it. guy who bought it direct plumbed from the tank past the small diaphragm pump/tap and problem solved. Quote
Vintage Grumble Posted September 21, 2017 Posted September 21, 2017 @kickerIts a timing belt (thought it was a v-belt/couldn't see on my phone) 375-5M, and I happen to stock it, so can cut it at 6mm wide for you. They would be $4.70ea + freight down to ya'll. 4 Quote
kicker Posted September 21, 2017 Author Posted September 21, 2017 6 hours ago, Vintage Grumble said: @kickerIts a timing belt (thought it was a v-belt/couldn't see on my phone) 375-5M, and I happen to stock it, so can cut it at 6mm wide for you. They would be $4.70ea + freight down to ya'll. Cheers dude, will pm you Quote
kicker Posted September 21, 2017 Author Posted September 21, 2017 I'm gonna go through it all bit by bit and check everything again, will give me a chance to clean up a few parts too. Have enjoyed riding this thing the few times I've been out, it rips along when it's on pipe 3 Quote
kicker Posted September 22, 2017 Author Posted September 22, 2017 Okie doke, bit by bit the checking starts. Just checked the fuel flow through the tap. The black line on the measuring cup is 50ml which it takes about 10 seconds to reach. Not sure on actual flow rate required but at 300ml per minute it'll empty the tank in about 17. Once my new plug cap turns up the next will be to test it with the engine running to see if it is the same. In the mean time I'll dig out my stash of sweet yellow Tygon fuel hose and shiny new clamps and replace both vacuum and supply hoses. 2 Quote
kicker Posted September 22, 2017 Author Posted September 22, 2017 Bam, 2 minute job but I'll count it as a win 6 Quote
oldnrusty Posted September 23, 2017 Posted September 23, 2017 Nothing wrong with that rate of flow in my (super amateur spec) experience 3 Quote
kicker Posted September 27, 2017 Author Posted September 27, 2017 Shout out to GC @Vintage Grumble, sorted me a couple belts, chur my bro 6 Quote
kicker Posted October 17, 2017 Author Posted October 17, 2017 I have been a bit slack lately but have been attempting to vacuum test the crankcase and intake. After trying a few different methods it still won't hold a vacuum so next step is to blow some air in and see if I can see where it's coming out. 1 Quote
MKD Posted October 17, 2017 Posted October 17, 2017 Not that ive ever heard of or seen it done, but if you put a couple of dry ice pellets in the intake then tested it would they leak visible gas out any holes/leaks? or soapy water test on outside. But youd be more scientitian with dry ice Quote
kicker Posted October 17, 2017 Author Posted October 17, 2017 Not a bad idea, maybe I could vape into it then sniff out the source of butterscotch and hipster 4 5 Quote
Raizer Posted October 17, 2017 Posted October 17, 2017 It could give you a good excuse to split the case and reseal it with some fresh case sealant and new gaskets? While your in there it wouldn't hurt to throw in a couple new crank bearings, maybe port out the intake channels in the case and polish everything in there while it's apart... Quote
kicker Posted October 17, 2017 Author Posted October 17, 2017 Hopefully I won't have to do that, already got one two stroke engine that has been sitting in bits for a couple years Quote
kicker Posted October 19, 2017 Author Posted October 19, 2017 Gave it a blow today, could very clearly hear air escaping from the left hand side of the engine behind the starter gear. Once I make a little puller to get the gear off I'll be able to see whats up with the seal, must be proper fucked though as I can blow a lot of air through it. Stay tuned, or not 2 Quote
