Shakotom Posted November 12, 2015 Share Posted November 12, 2015 Scored this off Guypie back in April for a steal. Untitled by OR4NGE, on Flickr Its in unknown condition, partially dismantled and has something wrong with the kick start causing it to jam everything up when kicked. Plan is to get it going and chop it up to make it less dorky. I pulled the covers off the drive side and found the kickstart was missing the cir-clip that limits the travel so it was over extending and jamming into the clutch. Rummaged in the tool box and found a couple of cir-clips with a 16mm internal diameter to match the shaft. Fitted them and rechecked. Engages with the kickstart gear, turns the motor over and doesn't jam. MINT But the kickstart lever doesnt spring back into position like all other bikes kickstart levers do Untitled by OR4NGE, on Flickr Untitled by OR4NGE, on Flickr With being able to find next to no information of NF75's on google and minimal motorbike knowledge... Anything there look out of the ordinary? Next lot of questions for you lot. [/url]Untitled by OR4NGE, on Flickr Motor turns over easy and appears to generate some form of compression but when i removed the carb to clean that out, found the crankcase has some signs of rust/water damage. leave it and run it or pull it apart and clean it out? or see if it runs and then dismantle and clean properly later? Untitled by OR4NGE, on Flickr the rear hub is a reduction gear drive setup and lever seems to engage/disengage drive. Untitled by OR4NGE, on Flickr carbs off and ready to go to work to be cleaned out tomorrow. Nearest bit of info ive found is a manual on a honda PA-50 which seems a bit hit and miss. chyeah 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted November 13, 2015 Share Posted November 13, 2015 if you pull that apart you will replace everything flush it out, replace the oil a few times and let it all "lap" backtogether and try pretend you saw nothing 2 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted November 14, 2015 Author Share Posted November 14, 2015 Filled crankcase up and Soaked it all in CRC/combustion chamber cleaner/parts cleaner gave a bit of a scrape and got all the loose stuff off. And cleaned/ rebuilt crab so put that on after turning engine upside down to get all the liquid out. She'll be right. (125cc Honda clones are cheap enough if it packs a sad) Just trying to find a coil as coils goosed mate Honda shops had it since Wednesday and no luck so far Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted November 15, 2015 Share Posted November 15, 2015 My wife got given one of these, real original but has a bung stator or something. Can provide help with anything other than that, haha. Internet has zilch info aye, it's shit. 1 Quote Link to comment Share on other sites More sharing options...
MKD Posted November 15, 2015 Share Posted November 15, 2015 https://lh3.googleusercontent.com/proxy/8FcAa_4uDzkEiFrTGSON6IEPDg1i0px9ME_2buPCs2-ZXslxkWUVGekuiO15mQuxF6TeG2u4NWyO9goFuOBKEUV4Rft4C-1D29wnoOk=w443-h332-nc http://stores.ebay.co.uk/bikedatauk?_dmd=1&_nkw=Nf75 Pa50 hobbit / camino has the same vmatic trans so possibly witing etc is similar? 1977mopeds definitely has the stators for a hobbit camino Bout as good as i can find.. 1 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted November 19, 2015 Author Share Posted November 19, 2015 This is the aforementioned circlip that was/still is giving me grief. It will hold fine for about four kicks them will slightly pop out of the groove and let the kickstart over extend and jam up. So every four kicks, Its poke it with a object and itll sit back into the groove DSC_0464 by OR4NGE, on Flickr I pulled the carb off, and took it to work to soak in carb cleaner Untitled by OR4NGE, on Flickr Gave it a once over and put it all back together Untitled by OR4NGE, on Flickr First thing I wanted to do was check for spark but,as it was missing a spark plug, and the HT lead coming out of the coil was fairly well past its used by date, and the lead being part of the coil. I checked for power to the coil. Yup. Took the coil/bike details to my local Honda motorcycle shop to see if they could find me a coil/plug. Gave it a few days with out hearing back from them so went and collected my coil off them. "waiting for honda to reply to our email" Meh.I wanted to see if this will run before spending money on it really, so pulled the lead out of the coil, stripped some insulation off some left over HT lead from when I made a new lead for the FA50, Jammed that in the end of the coil and checked continuity. Yup. Scavanged a plug end off a old set of leads and jammed that on the end of the HT lead. Spark plug from a two stroke stationary engine to check for spark. PRESENT AND ACCOUNTED FOR! Assembled all that onto the motor, mixed up some fuel and put that in the tank. Primed the carb and about 30 odd kicks later, It spluttered into life and smoked like a train as there must still be carb cleaner/crc mix from crankcase. Turned it off, Pumped up the tyres, Fitted the drive belt and gave it another kick and it coughed into life. So of course, I engaged the drive to the rear wheel and gingerly rode it down the drive and back. (no brake cables) So it runs. whats next? of course not making sure the carbs set up right ectect... I removed the huge seat, carrier rack, indicators, headlight and all the unnecessary things. Flipped the bars, screwed some bolts into the rear passanger foot rest mount holes as they are missing and ended up with this. DSC_0454 by OR4NGE, on Flickr Plan is to of cousrse get it running a bit better, because it doesnt go very hard for a 75cc bike (I think the FA is quicker at present) safety stuff like get the rear brakes working, new fat tyres. and minimise the wiring to just the basics to run it Then look into getting new bars so they sit in front of or in line with the forks. sort a low profile seat and probably hardtail the rear end/lower the front DSC_0457 by OR4NGE, on Flickr 4 Quote Link to comment Share on other sites More sharing options...
MKD Posted November 20, 2015 Share Posted November 20, 2015 If you wire those two holes on the circlip together would that stop it popping off? 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted November 20, 2015 Share Posted November 20, 2015 clean out the slot and use a new clip. that will probably fix it, i bet its bent/stretched 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 20, 2015 Share Posted November 20, 2015 And just stuff a vernier in there to measure size and get a new clip? Edit. Damn had this page open for ages before I replied. Quote Link to comment Share on other sites More sharing options...
tortron Posted November 20, 2015 Share Posted November 20, 2015 pretty much right. bad day when it pops out and gets stuck in something important Quote Link to comment Share on other sites More sharing options...
Shakotom Posted November 25, 2015 Author Share Posted November 25, 2015 For about the 12th attempt of writing this reply before phone closes the page/doesn't post. I fitted a brand new circlip from local engineering shop, but the problem is that the groove the circlip sits in is worn slightly, it has worn into a slight ramp on the outer edge so it gradually works its way up/open. I really need to pull it out so I can get it opened up to fit a second circlip in there properly which will also get rid of the slight play in the circlip in the groove which probably doesn't help. Might try wiring it shut for now as a temporary fixture for the weekend. Got new parts sitting at bike shop for it, so I should get that when I get home tomorrow! 1 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted December 4, 2015 Author Share Posted December 4, 2015 Got a new coil, and the correct plug for it the night before Dromeageddon. fitted them and rode it to the bottom of the street and back. Ran okay. Loaded it into the trailer and took it down. Kick started it, rode one lap and it cut out. Fiddled with carb, Kickstarted again and it jammed up. It ejected the circlip into the grass never to be seen again. Went to Repco and bought a multi pack of circlips. Fitted that and rode one lap before it lost all drive to the rear wheel. NF by OR4NGE, on Flickr At Sams, I decided to fire it up one more time to see what was wrong with it. It started and ran like a champ and magically fixed all its previous issues over night but was gutless. So I removed the exhaust and it went way better. Hooned around the dirttrack for a bit and forgot it only had a front brake which resulted in some super sketchy moments. 1 Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted December 4, 2015 Share Posted December 4, 2015 Nice work! Does it have any form of tensioner on the drive belt? Ours seems quite loose so not sure if missing something/stretched/wrong belt Quote Link to comment Share on other sites More sharing options...
Shakotom Posted December 4, 2015 Author Share Posted December 4, 2015 Nah, just stretch fit over the pulleys. Belt is fairly loose as it's the original belt in guessing, but it didn't slip or anything 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 21, 2018 Share Posted January 21, 2018 MINE, thanks @Shakotom Going for the rusty minimalist look, I got stuck in today. Still full of enthusiasm from the ride yesterday. I realized the other half of the swingarm was under the belt guard (I thought the belt side was completely different until looking)- so drilled out the spot welds. Then removed a few other bolt on brackets and ordered another coil 3 in the box, the only one that kinda worked sent millions of volts through the frame like some kinda april fools gag. I also calculated the size of my new fuel tank- exactly two liters. How big is the tank on that bike you had yesterday Tom? 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 21, 2018 Share Posted January 21, 2018 also, @Raizer @64vauxhall @Shakotom @MopedNZ etc best tires for this? 14" and need to look badass Quote Link to comment Share on other sites More sharing options...
Shakotom Posted January 21, 2018 Author Share Posted January 21, 2018 ST has a fuel tank of 2.5 litres just from memory, I think guypie told me that the fuel tank / oil tank separating bit have failed and it’s all sort of one. run pre mix 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 21, 2018 Share Posted January 21, 2018 Will have to run premix as only going to hsve one tank. 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 23, 2018 Share Posted January 23, 2018 Yep tank had a hole into oil chamber. 5 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 26, 2018 Share Posted January 26, 2018 Its now hollow and getting some bondo. Cant decide if get greg to cover whole thing or not 1 Quote Link to comment Share on other sites More sharing options...
