FlyingBricks NF75
Shakotom
  • Replies 58
I wire wheeled the insides and then smeared chassis adhesive/sealant all along the seam from the two steel halfs.. then glued  and bolted in the valve cut from the old tubes.. then put tires on.
Wow SO EASY FITTING TUBELESS TIRES. actually only took a few minutes with no tube to worry about fucking.
Didnt end up as wide as expected because the rims are so narrow but YOLO
I've got one of thrse. Got from the bookface not running.
Got it running but needs new coil.
Went hard just about pulled from the wheel off ground from a start
Something I loose in my rear wheel. Kinda like bearing has colasped.
Have you have yours apart?
  • 5 weeks later...
  • 2 years later...
On 22/03/2021 at 20:27, kp123123 said:
Can you help me with some advice on kickstart please
Broken the kickstart shaft return spring completely snapped can you please tell me how to get the shaft spindle off and what side would it come off from the drive belt side or opposite thank in advance
On 25/03/2021 at 22:38, flyingbrick said:
Wow!!! That's a damn tidy one, looks great!!!!!
I'll take a look at mine tonight and see what information I can give you about that shaft.
Managed to source a spring and get it fitted with help from a friend was a job and a half
  • 2 years later...
I know this is an old thread but I’m running out of options. Hopefully I get a response. Bought a 1980 NF75. Runs amazing when cold but as soon as it warms up it’s won’t rev and clangs whenever I try to rev it. Checked the Carb, tried a smaller and larger jet but it’s just not working. I have noticed the previous owner has used silicone between the head and crank case so assume this could be causing me the issue. However there’s no info out there and gasket kits are only listed till 1979
