M Night Shamalayan Posted September 17, 2016 Author Share Posted September 17, 2016 That's actually a genius plan. Makes it easier to procrastinate on that WOF too. Lol 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 17, 2016 Share Posted September 17, 2016 King of procrastination. Will probably take you a month just to walk the 5min down the road to the gas station for some gas lol 1 Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted September 17, 2016 Author Share Posted September 17, 2016 i just used the premix two stroke i had for the weed eater to get it up the drive. 2 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 17, 2016 Share Posted September 17, 2016 Ffs Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted September 17, 2016 Author Share Posted September 17, 2016 haha kidding Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 18, 2016 Share Posted September 18, 2016 I don't believe you lol Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 18, 2016 Share Posted September 18, 2016 it needed the extra jizz in the bores anyway. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 18, 2016 Share Posted September 18, 2016 Did it smoke less with the premix 3 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 1, 2016 Share Posted October 1, 2016 maybe its that mobil gas to extreme Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted October 1, 2016 Author Share Posted October 1, 2016 added too many horse power and it cant handle it. Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 1, 2016 Share Posted October 1, 2016 Doubled it to 2? I find that hard to believe. Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted October 1, 2016 Author Share Posted October 1, 2016 those petrol adverts make some extreme claims, but im inclined to believe them. I might sue for damages. Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 1, 2016 Share Posted October 1, 2016 I've found that old cars don't like the Mobil fuel. One of my triumphs would hardly run on it, had to play with the timing to get it to run semi ok. All the gas was fine. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 1, 2016 Share Posted October 1, 2016 Are you getting spark at the coil? Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted October 1, 2016 Author Share Posted October 1, 2016 how do i check that without killing myself? all the books i have tell me how to pull it apart, but give no explanation on how to actually diagnose shit haha. Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 1, 2016 Share Posted October 1, 2016 Check for spark at the spark-plug end first would be the go. Take out one of the plugs, attach the lead back onto it and earth it against something and then wind it over, if you can see spark then the coil is OK or at least working in some capacity. (pun) Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted October 1, 2016 Author Share Posted October 1, 2016 nyah-ha! there is absolutely no spark at the plug, that i can see. i earthed it against the engine, which i presume should be a reasonable ground point? Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 1, 2016 Share Posted October 1, 2016 nyah-ha! there is absolutely no spark at the plug, that i can see. i earthed it against the engine, which i presume should be a reasonable ground point? Yes, that is a good ground. Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 1, 2016 Share Posted October 1, 2016 Have you got a multimeter to check that there is 12V at the coil? Also, remove the distributor cap (usually held down by a couple of clips) and check that the points are opening and closing as the engine cranks. 2 Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 1, 2016 Share Posted October 1, 2016 Sounds like you got a good rogering! Good work that man. 3 Quote Link to comment Share on other sites More sharing options...
