d.p.n.s Posted April 28, 2015 Share Posted April 28, 2015 Hi all Nissan calipers turned up today. After a quick look I can get 1 bolt in and the calipers mount flat to the mounts so no room for a think adapter plate. All ideas welcome //oldschool.co.nz/uploads/monthly_04_2015/post-5858-0-91884100-1430192630.jpg //oldschool.co.nz/uploads/monthly_04_2015/post-5858-0-12154200-1430192641.jpg//oldschool.co.nz/uploads/monthly_04_2015/post-5858-0-04591900-1430192654.jpg //oldschool.co.nz/uploads/monthly_04_2015/post-5858-0-48916100-1430192665.jpg Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 Sorry pics didn't work they are in the last post on my build thread if you can't see them here. Cheers Quote Link to comment Share on other sites More sharing options...
taiparacer Posted April 28, 2015 Share Posted April 28, 2015 can u measure the bolt spacing's on the bottom of the strut and then the bolt spacing on the calliper for me cheers ron Quote Link to comment Share on other sites More sharing options...
Nominal Posted April 28, 2015 Share Posted April 28, 2015 That's going to be hard to make work. Maybe take a trip to pick-a-part and look for some calipers with a different 'offset' to the mounts so that there is room for an adapter plate. Otherwise, something like a 4-fingered E adapter could be made, and rotate caliper down to provide room. Would need to be welded though, and could be difficult to cert. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 can u measure the bolt spacing's on the bottom of the strut and then the bolt spacing on the calliper for me cheers ronCortina hub 82mm center to centerNissan caliper 100 km c 2 c Quote Link to comment Share on other sites More sharing options...
cletus Posted April 28, 2015 Share Posted April 28, 2015 plus you have a mismatch of disc/caliper thickness- 19mm disc vs a caliper designed for a 30mm thick disc may end up with a problem with pads falling out or jamming when they wear 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 plus you have a mismatch of disc/caliper thickness- 19mm disc vs a caliper designed for a 30mm thick disc may end up with a problem with pads falling out or jamming when they wear These are off a non turbo 300zx and are the smaller ones..still all alloy but just 26mm gap not the huge 30mm.. So a wee bit bettet Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 28, 2015 Share Posted April 28, 2015 Should be able to split the calipers and machine them down to correct width. Also please post pic. May need to rotate the caliper around a bit to make room to make an adaptor. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 Should be able to split the calipers and machine them down to correct width. Also please post pic. May need to rotate the caliper around a bit to make room to make an adaptor. Some one did yell me about machining them down... I tryed to add pics in the 1st post but it won't let me..I did put 4 pics in my build thread .( link in signature. As for rotating it if I moved it down it may foul the steering arm.and if I move it up its behind the strut leg. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted April 28, 2015 Share Posted April 28, 2015 Bigger diameter disc with more thickness, move caliper outwards = profit? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 Bigger diameter disc with more thickness, move caliper outwards = profit? No that would be to easy. Took me agers to find a disc that would bolt to the cortind hub with no machining. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 28, 2015 Share Posted April 28, 2015 Ohh I see pic. Nah that's a bit shit fit a. Sell them to some drift queen and buy some wilwoods or something with much wider holes. Eg wilwood dynalite have 133mm ish hole centres Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 28, 2015 Share Posted April 28, 2015 Or Wilwood can come in the exact size to bolt straight on. Browse US or UK ebay can often get an older set for a steal. Old man got some delivered to NZ for under $200 for both (Ford pattern). No pads tho. Those discs you've used... do they provide same offset as standard? Cant say I came across those when looking for upgrades all those years ago, and I read the shit outta the DBA catalog. Wonder if I could use on my mk1 with the standard calipers spaced to suit. Gaz Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 28, 2015 Share Posted April 28, 2015 Or... works in my head but may be thinking wrong. Make an adaptor that bolts behind both lugs. Then it curves same circ as disc upwards and steps back out to same width as lugs. Maybe can get one hole between current lugs and one slightly higher? So moves caliper slightly above std but keeps same plain. Gaz Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 28, 2015 Share Posted April 28, 2015 or does that closer to strut than it looks in pics. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 28, 2015 Share Posted April 28, 2015 The caliper looks like it's not sitting down over the disc enough in the pics?? Quote Link to comment Share on other sites More sharing options...
fletch Posted April 28, 2015 Share Posted April 28, 2015 Should be able to split the calipers and machine them down to correct width. Done this before. Easy to do. Take the same off each half. Keep the o ring hole the same and it will be sweet. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 Or Wilwood can come in the exact size to bolt on. Browse US or UK ebay can often get an older set for a steal. Old man got some delivered to NZ for under $200 for both (Ford pattern). No pads tho. Those discs you've used... do they provide same offset as standard? Cant say I came across those when looking for upgrades all those years ago, and I read the shit outta the DBA catalog. Wonder if I could use on my mk1 with the standard calipers spaced to suit. Gaz The discs are ke 1600 fire laser turbo.not sure on offset .just wanted a vended disc that bolted on. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 Or... works in my head but may be thinking wrong. Make an adaptor that bolts behind both lugs. Then it curves same circ as disc upwards and steps back out to same width as lugs. Maybe can get one hole between current lugs and one slightly higher? So moves caliper slightly above std but keeps same plain. Gaz Only about 2mm between back of Mount and disc.... So I don't think there is enough room. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2015 Author Share Posted April 28, 2015 The caliper looks like it's not sitting down over the disc enough in the pics?? Just look funny in pic. Quote Link to comment Share on other sites More sharing options...
