so this happened today
1662278_10152971865722534_59555208334558
Ordered a whole lot of metal so will have some wheels to stick it to when I make some other bits
Lots of fail to follow
  • Replies 139
So I got busy with some steel and a drop saw today
then I did this:
10868234_10152976237177534_8473010836749
I need to add some cross beams and springs and shit
then some wheels
Not sure if it's any good to you, but I have these sections of ply:
I just grabbed them to sit things on in storage, but if you want them to use on this, I can even drop them over at some stage. From memory it's about ~12mm thick and the reverse side is plain ply.
I incresed the front radius from 300 - 750 and it looks much better.
Trailer base finished.
Pick up springs and stuff in the weekend, then I will add a drawbar etc. then the hard stuff starts
Edit;
10940538_10152977433517534_6660920639376
there is the piece I removed off the front radius (and the jigsaw is unplugged!)
Man. You look different without your beard
i think you have just increased the looks and lines of this thin 10 fold. How big is it? Anglebox tow car?
Have seen sidevalve minors towing them, but hills must be torture
speed holes (except for the door)
They will get filled with foam/insulation and skinned in ply or something on both sides.
Looking good! def not nedding around are you :)
Ned, I am doing my best! I am on a 12 week build timeline
I hope to get her campable for school hols
12? i'm hoping to do mine in 6, and i havent even started yet :P
are you going to have a galley or just living space?
It will have a simple galley in the fold up hatch that is scaring the shit out of me.. (all OS Kero appliances)
