felixx Posted March 31, 2015 Author Posted March 31, 2015 The insulation: It looks like arse at the moment, however it will get tucked in nicely before I glue and screw the roof in. It is a woolen batt so will be good at insulating Here is my overhead shelf, you can just see the switches in the RH side (on the underside) 3 Quote
felixx Posted April 3, 2015 Author Posted April 3, 2015 So Ned/ Bantam mainly, but Born Loser may know being a coach builder and all.. Should I skin the sides or the roof first? I was thinking sides because the piece of ACL I have for the roof is wider than the caravan so I can cover the 'edges' (There will be aluminium flashing going on too) Quote
Chris.QCR Posted April 3, 2015 Posted April 3, 2015 Sides first and then leave 20mm of the roof each side to tap lightly over the edge to cover the the side . Creates a better seal . Assuming you are covering the roof with 0.9 mm alloy sheet . If fibreglass sheet then it doesn't matter which way Quote
Chris.QCR Posted April 3, 2015 Posted April 3, 2015 Can possibly come around and throw some advice on things 2 Quote
felixx Posted April 3, 2015 Author Posted April 3, 2015 Hi Chris, I am using Sign Board (4mm thick) and will use unequal angle Aluminium as flashing. Youre welcome to swing by and throw some advice at me Quote
felixx Posted April 3, 2015 Author Posted April 3, 2015 So I got the lino in the galley and finished the wiring.. So here I am by the campers lights (no flash) so I reckon they are plenty bright New Lino in the galley Battery box in place 1 Quote
ODB Posted April 3, 2015 Posted April 3, 2015 Starting to look pretty good bud. Come a long way since last time I saw it even! 1 Quote
felixx Posted April 3, 2015 Author Posted April 3, 2015 Will get the 4x2 for the anchor for the hatch tomorrow Quote
Bling Posted April 3, 2015 Posted April 3, 2015 How much 4x2 you need? I'm sure I can find some and drop it off next week *shifty eyes* Quote
felixx Posted April 3, 2015 Author Posted April 3, 2015 Ahh Its only 4 feet, its like $5 bucks worth, but thanks.. Txt if you have some free time over my side of town, alwys a beer/ coke or hot cuppa 1 Quote
Ned Posted April 3, 2015 Posted April 3, 2015 i would probably do the sides, then flush trim them with the router, and then do the roof? i'm sure it doesnt really matter, but if you do the roof after, then if water does come in between the roof and the trim, then it has to work harder to get inside as there is no seam on the roof as such (no idea if i'm making sense TBH) 1 Quote
Bling Posted April 3, 2015 Posted April 3, 2015 Txt if you have some free time over my side of town, alwys a beer/ coke or hot cuppa You'll be camping in it by the time I can manage that sadly. 12 hour days / 6 days a week for another couple of months. If you ever need random building materials though hit me up. The amount of wastage of jobs is silly. Quote
felixx Posted April 4, 2015 Author Posted April 4, 2015 AWESOME! My neighbour just arrived with some inner spring squabs for my caravan, they were from his caravan, he justreplaced them. Perfect fit too! SCORE!! 1 Quote
felixx Posted April 4, 2015 Author Posted April 4, 2015 Got quite a bit done so far.. got the skins glued to my door interiors: (didnt have enuff clamps so I improvised) Here are the (inner sprung) squabs Tomorrow I finish the doors (insert lock mechanisms etc) 1 Quote
Mof Posted April 4, 2015 Posted April 4, 2015 Wow perfect fit Although that tube of glue could be a bit lumpy/uncomfortable And extra springs to go sqeekee squeekee squeekee all night Edit to add wink wink nudge nudge say no more Quote
felixx Posted April 4, 2015 Author Posted April 4, 2015 Mocked up the doors: wiley window open: wiley window closed Wiley window ventilation mode progressing slowly 4 Quote
felixx Posted April 7, 2015 Author Posted April 7, 2015 Well got a door cut out today: And the other side cladded.. roof tomorrow?? then off to buy supplies to make the hatch and alloy trim 3 Quote
felixx Posted April 8, 2015 Author Posted April 8, 2015 umm yeah.. it is not perfect but it will do! Rear hatch next, then the doors! It is amazing how an hour or 2 a day gets it along! Start the new job tuesday 5 Quote
