W55-58 behind a rotary
maxted
Just wondering if anyone on here have run a w55-58 behind a rotary, i have got a w56 and a s4/5 rx7 bellhousing, ive just brought an adaptor too suit, wanting to know what set-up you need to use clutch wise, do you use all rx7 stuff except a supra splined clutch disc? Any help is much appreciated
Have the same setup but with a w57
Use the flywheel/clutch size that your bellhousing is suited too so 8.5 if rx3/oldschool bellhousing and 9.5 if a turbo one, with a supra splined disc of the matching size.
Have heard the spline length can be an issue but I brought mine as a kit so didnt have an issue.
Can anyone confirm the thrust bearing surface has to be shortened slighty?(otherwise the kit comes with a bush to suit)
sr1600- cheers for the info, do you also run rx slave cylinder and fork?
nzed- I had heard this also regarding rubbish ratios and the selector forks being a weak point, but i got the box really cheap and will just replace with a w57/8 if i have problems down the track, but at the moment it will do to make mounts and get through certification, its only going to have a standard 12a to start with so won't be getting a rough time. cheers for the help
Clutch slave cylinder bolts to the motor , try and run the matching master to keep the stroke ratio the same. The clutche ive had done a autoclutch come back with a warning stroke should not exceed 10mm at the slave (may be because I had a billet pp)
those j160's are sweet. as long as you don't limiter dump everywhere and don't run a stupid clutch like a 4puk or something everything will be fine.
Looking back i should have used one on my cressida with a 1ggte. Same raitos as a w55 but 1 more gear. 4.11 final drive for both of them.
RX8's don't have a speedo drive in the gearbox, they get their speedo reading off the ABS sensors on the wheels.
looked into it awhile ago, would have to fiddle with things/make something up to make the speedo work.
main reason for going with w series box is I picked up the w56 for cheap and already had the bell housing and found an adaptor for $100, even tho the ratios aren't flash i can swap it out for a w57/8 at a later date, saves changing the whole set-up from s1-3 later on, and my little bro wants the s1 box for his escort his one is knackered
yeah its only a standard 12a at this stage
