flyingbrick Posted November 30, 2012 Share Posted November 30, 2012 I would not be worried about their legality. I would be worried about my stitching holding up in an accident. Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted November 30, 2012 Author Share Posted November 30, 2012 Yeah the stitching would be a worry - half way through the windscreen going "damn, wish I could sew better...". You might find an upholsterer that could do the stitching for you with a heavy thread/industrial machine. I wouldn't trust my sewing on a belt. Buttons regularly fall off my shirts once I've tried to stitch them back on, and my recollection of intermediate school sewing is not good (I was more interested in how the sewing machine worked than the actual joining of fabric). I did find one place that knew of a place in Oz that could re-manufacture belts, but I imagine you'd run into issues with going to an inertia reel. My car for instance doesn't have a mounting point on the B pillar for the top piece, it's behind the driver's seat under the side window. Must be loads of info on the 'net about conversion. I'm just going to put in modern belts for the WOF ($90 each) and sort the rest in the future. Safety First Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 30, 2012 Share Posted November 30, 2012 I'm quite a girl when it comes to sewing. I'd not be worried about doing it but would seek good thread from upholsterer friend. More just wondering if they would spot that I have retractables with old school clasps. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted November 30, 2012 Share Posted November 30, 2012 With retractable the key would be to pull them all the way out, then the belt slides off the drum. just make sure you dont let the drum unwind. There is a small loop in that end of the belt with a platstic bit inside. With the plistic bit out you should be able to slide off the buckle, fit desired buckle and re assemble. I really wouldn't recommend restitching any part of a seatbelt that takes the force of impact. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 30, 2012 Share Posted November 30, 2012 You can buy some pretty sweet retractable belts from a hot rod upholsterer called Julianos in the states. Would pay to check they pass the safety standards here but they are legit for hot rods stateside. Quote Link to comment Share on other sites More sharing options...
cletus Posted December 1, 2012 Share Posted December 1, 2012 yep belts have to have a safety standard marking on them....eg, if its US it wil be FMVSS106, euro stuff has E in a circle, NZ aust is NZS2596 have seen an indians van that had diy belts stitched up with fishing nylon.....eek. modifying belts yourself is a no-go Autoliv used to do belts here but they have closed up shop, only in oz now. Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted December 1, 2012 Author Share Posted December 1, 2012 Sweet, they have their own online shop http://www.seatbeltstore.com. Still doesn't let me keep the Vauxhall clasps and hardware though. I'll just get over it and roll with modern ones. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted December 1, 2012 Share Posted December 1, 2012 I'll do some sweet embroidery while I'm at it. Quote Link to comment Share on other sites More sharing options...
yeah yeah na Posted December 1, 2012 Share Posted December 1, 2012 try rodger at seatbelt solutions 095800386. hes pretty busy so sometimes seems slack, but keep on him, the end result is worth it. Quote Link to comment Share on other sites More sharing options...
Bling Posted December 2, 2012 Share Posted December 2, 2012 Sweet, they have their own online shop http://www.seatbeltstore.com. Still doesn't let me keep the Vauxhall clasps and hardware though. What about sending them the clasps you have and getting them to make belts with them on? May or may not work, just throwing the idea out there. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted December 9, 2012 Share Posted December 9, 2012 Mike Fiddymont on Brougham Street down here replaced the webbing in the van with matching green stuff. They are retractable, but... worth a call. Quote Link to comment Share on other sites More sharing options...
