Mysterious clicking noise from engine...
savageoutlaw
Cruising around yesterday, and after about 70kms, there was a mysterious clicking noise coming from the right hand side under the bonnet.
Coming from either:
  • -Carbs?
    -Extractors?
    -Anything around this area of the car??
Speed of ticking would increase while accelerating, but there was a certain time when it wouldn't click. Going around 80kmp/h it would hush..
A15 Datsun Engine. Twin SU style carbs. New custom made extractors...
Recently oiled them, and still needing to find air filters so anyone with some 1 1/4" ram flows or similar wanting to sell would be nice too :)
Should I be concerned or not?
i assume its not big end bearing knock? though that wouldn't disappear at a certain revs i don't think, unless it was a weird resonant like phenomen
thats exactly what big ends do before they get superfucked and knock the whole time. will rattle knock at a certain rpm
trust me i've done it in 3 cars and two engines on the same bike lolol
this^ plus timing chain tensioner on a 1256 was so lols,
would rattle click etc when cold,
machine gun rattle under load but not knock,
then knock just off idle pulling away from lights.
timing chain on an a15 is probably as simple as it gets,
go buy a haynes manual and have a read up,
it'll even list the tools you will require,
and then it'll direct you step by step through the whole process to replace the parts,
also could well be a loose tappet!
