Seedy Al Posted August 23, 2012 Share Posted August 23, 2012 hey Guys So the dairy owner from across the road from me failed to heed my warnings ages ago about his cam belt, and yesterday it finally gave up on them So question. is the 3sfe a non interefernce motor? So no bent valves?? I have alway thought they are but I would preer to here it from someone who knows LOKL Chur bits Quote Link to comment Share on other sites More sharing options...
Ranter Posted August 23, 2012 Share Posted August 23, 2012 Dunno whats it in? Camrys with the 5sfe never hit even though the books say they should. Quote Link to comment Share on other sites More sharing options...
Beaver Posted August 23, 2012 Share Posted August 23, 2012 first three google results (toyota forums) say non-interferance. Quote Link to comment Share on other sites More sharing options...
durty Posted August 23, 2012 Share Posted August 23, 2012 Tell him it's interference and charge him to replace engine but only do the cambelt most other mechanics would do it Quote Link to comment Share on other sites More sharing options...
durty Posted August 23, 2012 Share Posted August 23, 2012 But seriously I'm 99% sure non interference. I think that's what I had in one of the toyotas I had and was all g after snapping Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 23, 2012 Author Share Posted August 23, 2012 dude I'm not a cunt remind me not to get my car fixed anywhere where you take it Cool thanks guys, guess I have a eprky next week then Quote Link to comment Share on other sites More sharing options...
fulloc Posted August 23, 2012 Share Posted August 23, 2012 pretty sure all -fe are non interference. ? Quote Link to comment Share on other sites More sharing options...
danger Posted August 24, 2012 Share Posted August 24, 2012 Pretty sure its non interference. Either way I have a good '91 camry top end here if you need it or any parts Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 24, 2012 Share Posted August 24, 2012 My cousin popped a cam-belt on a 3sfe and it was fine. Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted August 25, 2012 Share Posted August 25, 2012 Funny you should bring this up, I have just done the same job today for the same reason, on a corona. they don’t bend valves . and the belts tend to snap because the oil pump seal and housing seal leaking, and the oil makes the belt swell and in turn fuck out, so best to do all the seals and water pump if money permits . If you buy the cam belt kit it will come with seals tensioner idler and oil pump housing seal. Water pump is extra. Quote Link to comment Share on other sites More sharing options...
camo_78 Posted August 25, 2012 Share Posted August 25, 2012 i did the belt on a vista with 3sfe power,99% sure non interference so should be safe Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 26, 2012 Author Share Posted August 26, 2012 Funny you should bring this up, I have just done the same job today for the same reason, on a corona.they don’t bend valves . and the belts tend to snap because the oil pump seal and housing seal leaking, and the oil makes the belt swell and in turn fuck out, so best to do all the seals and water pump if money permits . If you buy the cam belt kit it will come with seals tensioner idler and oil pump housing seal. Water pump is extra. yeah have done a few cam belts on these and have always replaced the Oil pump seal, silly toyota. Cam belt kits usually have them in as you said And always do the water pump also, have a laugh when people dont and 10 000km later its leaking, if that. Quote Link to comment Share on other sites More sharing options...
