fulloc
About fulloc
  • Birthday 04/24/1986
395 profile views
fulloc's Achievements
Advanced Member
Advanced Member (3/5)
0
  1. Could it be as simple as fouled plugs? and also what is the compression like? I had an issue with my series 5 once where it randomly wouldnt start one day, i thought it was toast. i tried a few things but in the end took it to glen monroe (rotary power) he fooled around with a 1m long phillips right down over the back of the top mount (i was young/ wasnt watching) he adjusted a screw of some kind and it was good as new.
  2. bridge e1 and te1 with a paperclip or wire (in the diagnostics plug) idle should noticibly drop. you can then chuck the timing light on and move the dizzy round to the desired point
  3. fulloc
    1G-EU Problem
    usually its timing related if you are getting intake backfire. no random vacuum hose or plugs fallen off anywhere? if i was still in welly id come help you out.
  4. fulloc
    1G-EU Problem
    have you touched anything? checked leads, plugs timing etc? blocked fuel filter?
  5. fulloc
    Td04 questions
    thats the drain back to the sump on the bottom by the sound of it
  6. If you can, do a compression test, then re do it with a small amount of clean oil poured into the bores. This will often pick the pressure up and indicate rings are worn. Sometimes rings just stick and you get a bit of smoke/ usase but not all the time which makes it confusing.
  7. pretty sure all -fe are non interference. ?
  8. or take in a sample and match it up to something old and nissan?
  9. looks like a good platform, that front lip is a good score too eagerly awaiting slam and wheels
  10. i find it odd that you would need a new camshaft without anyone pulling the motor apart to see what condition its in...? has anyone checked plugs, leads, cap, points, timing, fuel filter etc etc for you? where are you located? its the same engine as an eb civic too which are cheap to get hold of, very very easy to repair diy if you get the manual from a library or similar. i once taught a gf to do a cambelt on one of these i also know that the 1.6 sohc from the late 70's accord will bolt in to most early civics, probably easier than going efi with a city engine.
  11. you can drive it. i wouldnt drive far though... take the belt off if possible and leave fluid in it to lube
  12. always puts a smile on my face, ive got a little rust to cut out next but its pretty minor really. someones definitely looked after it. i need to get it in the garage so i can pull the sunroof and patch it up. luckily the roof is totally sound and i have only a few minor spots by the boot drain holes. looking at putting a 1gge in it next as i really want to keep it period specific and while the 1ge has enough torque to have fun in the wet it just wont rev. Also not really needing a cert is a plus.
  13. couple of pics from the recent welly meet. By fulloc at 2012-04-14 By fulloc at 2012-04-14 next on the list is get a little rust cut out. once i get set up in my new garage and the wof runs out il look at pulling the motor and putting something a bit better in. i also have a gt4 lsd which i will try get set up in the current t-series irs head. should make for a bit more fun in the wet
