LingLing Posted April 3, 2012 Share Posted April 3, 2012 Hi, as you probably know I removed the distributor and screwed up the timing for the panda which is 4age engine. I don't have the tools like timing light etc also have zero knowledge about the Job. So if anyone in akl area could help me set up the timing that would be awesome. I am bit broke at the moment but will get you a box of beer if that's ok. thank you in advance Andy 021 269 8650 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 3, 2012 Share Posted April 3, 2012 instructions were given in the other thread on how to do it yourself. Quote Link to comment Share on other sites More sharing options...
fulloc Posted April 3, 2012 Share Posted April 3, 2012 line up the marks on the cam and dizzy and try it till it works. you cant really hurt anything and theres only about 3 possible positions it will slip into. fuck i got my smallport running with a cam 180 out due to using the old owners timing marks and not checking it myself. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 as I have explained before I am not confident and lack of tools. If I make a mistake which probably will as it will be my first time, that could cost me the engine. Quote Link to comment Share on other sites More sharing options...
SP450andLE Posted April 3, 2012 Share Posted April 3, 2012 tbh, the only tools you need are what you took the dizzy off with. And maybe a timing light. I would help, but I'm allergic to toyotas Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 line up the marks on the cam and dizzy and try it till it works. you cant really hurt anything and theres only about 3 possible positions it will slip into.fuck i got my smallport running with a cam 180 out due to using the old owners timing marks and not checking it myself. this sounds easy. I will do some research and could do it I guess. 3 positions? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 3, 2012 Share Posted April 3, 2012 Yep, 3 positions - one tooth retarded - correct - one tooth advanced It's quite basic but I can understand a 1st timer looking at written instructions and going wtf. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 I don't even know what timing light is, also wtf is dizzy ? Quote Link to comment Share on other sites More sharing options...
fulloc Posted April 3, 2012 Share Posted April 3, 2012 dizzy = distributor youre either on the mark or one tooth forward or back. put a socket on the crank and wind the engine till the camshaft on the side of the engine where the dizzy is (exhaust cam) has a small notch visible on it at the cambelt end of the motor. this notch should be directly on the top at the correct position. you may need to pull that side of the rocker cover off to see properly. this wont hurt anything. next get the dizzy and have both the small holes in line like this http://i55.photobucket.com/albums/g122/ ... uild16.jpg insert the dizzy in with the hole on top, it will try turn left or right. simply let it turn as it slides in then bolt/ plug up and try it. this will take a couple of goes. one you have it running you can rotate the dizzy slightly till it idles smoothly and then get a friend with a timing light to later confirm/ set the timing exactly for you. timing light flashes when the spark runs through lead/cyl number one and lets you line the spark timing up with the notch on the crank pulley. this should do it. il try find you a pic of the camshaft mark too. *edited for poor english Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 3, 2012 Share Posted April 3, 2012 Don't forget you'll need to jump the t + e1 in the diagnostic connector during adjustment! Someone will need to show him guys... Quote Link to comment Share on other sites More sharing options...
fulloc Posted April 3, 2012 Share Posted April 3, 2012 my bad its inlet cam the mark is on, just take off the oil cap and turn engine over till you see this. http://www.pbase.com/aw11mr2/image/40045904 then do this http://www.pbase.com/aw11mr2/image/39365314 make us proud andy, we all learnt the hard way Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 I do follow fulloc, and I can do it I guess, will probably take me 1 day. but yeh I would like someone just standing around where I can do the work and he/she keeps drinking my beer. Quote Link to comment Share on other sites More sharing options...
Llama Posted April 3, 2012 Share Posted April 3, 2012 Yeah, I felt like that too first time I tried, but you can't really screw anything up. Just try and fail until success. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 Right, I am going to do it tomorrow as I think it is easy enough. but, "Don't forget you'll need to jump the t + e1 in the diagnostic connector during adjustment!" what does it mean? Quote Link to comment Share on other sites More sharing options...
Requiemk Posted April 3, 2012 Share Posted April 3, 2012 Does your computer not access google? https://www.google.co.nz/webhp?sourceid ... 66&bih=600 first link Quote Link to comment Share on other sites More sharing options...
Ned Posted April 3, 2012 Share Posted April 3, 2012 tl;dr does it drive? Find a timing light, come to my house and i'll do it. I believe $tephen has one? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 3, 2012 Share Posted April 3, 2012 Its fucked bad enough to not start - so it won't drive.. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 tl;drdoes it drive? Find a timing light, come to my house and i'll do it. I believe $tephen has one? ok, I will get it started, and will get Stephen or you to help me to set the exact timing. thank you ned. also, The car runs on Mega squirt, would the normal diagnose port work? Quote Link to comment Share on other sites More sharing options...
Ned Posted April 3, 2012 Share Posted April 3, 2012 oh, and download all of these http://www.aeu86.org/index/technical-ae ... topic=5158 and read stuff about timing etc. Also look in there before posting to get a rough idea of what the problem is. And if it doesn't go, i can come to you and do it if you have tools etc. Just see if you can borrow the timing light from Stephen (if he has one) Quote Link to comment Share on other sites More sharing options...
sentra Posted April 3, 2012 Share Posted April 3, 2012 you can purchase a timing light for cheaper than a box of beer jeasus 1 Quote Link to comment Share on other sites More sharing options...
