427carguy Posted March 11, 2012 Share Posted March 11, 2012 disscusion thread for viewtopic.php?f=17&t=32442 Quote Link to comment Share on other sites More sharing options...
felixx Posted March 11, 2012 Share Posted March 11, 2012 Hey man, was good to meet ya at gov's the other sunday. Was good to talk to ya last week too. Escort looks good. Quote Link to comment Share on other sites More sharing options...
Duddley Posted March 11, 2012 Share Posted March 11, 2012 Awesome lookin start dude. Those guards/flares standard on the gt? Quote Link to comment Share on other sites More sharing options...
427carguy Posted March 11, 2012 Author Share Posted March 11, 2012 The flares on the front are a copy of the factory rs flare, and from what i understand the rears are a wider copy of an rs flare?? Quote Link to comment Share on other sites More sharing options...
BDA780 Posted March 11, 2012 Share Posted March 11, 2012 Sweet looks good man. You gonna run a intercooler? Might see you at the Nats. Quote Link to comment Share on other sites More sharing options...
427carguy Posted March 12, 2012 Author Share Posted March 12, 2012 Im not planning on intercooling it at the moment but may have to if heats the air up to much Quote Link to comment Share on other sites More sharing options...
glen Posted March 14, 2012 Share Posted March 14, 2012 you wont be intercooling it if you intend on keeping the suck thorugh set up. you could look at some form of methanol/water injection, but tbh i recon it will be fine. Quote Link to comment Share on other sites More sharing options...
jeremiahnz Posted June 22, 2012 Share Posted June 22, 2012 Where did you get the tensioner rod you are using for the supercharger? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 22, 2012 Share Posted June 22, 2012 very nice mate love the rs colours and it seems to be in good codition. the supercharger set up lokks sweet Quote Link to comment Share on other sites More sharing options...
427carguy Posted June 23, 2012 Author Share Posted June 23, 2012 jeremiahnz: I Made It myself and its just a stay the idler pully is the adjustment Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 29, 2012 Share Posted June 29, 2012 Hey man, Just a thought. superchargers take a bit of power to drive. There will be quite a bit of load on that top tensioner at the back. If I were you, I'd add another anchoring point on the three bolts at the front which look like a bearing cover, and tie it to the thermostat housing. All the load will be at the front where the belt is, and your mount is at the back. I've heard of blower mounting brackets breaking. Or the bracktry will flex, and the belt will come off. Worst case senario would be the bolt hole where your rear mount is blowing out all together. After all, it isn't a big bolt, and the casing is only crappy old cast aluminium. Quote Link to comment Share on other sites More sharing options...
427carguy Posted June 29, 2012 Author Share Posted June 29, 2012 Cheers fort he advice man, the bottem bracket is pretty solid and the the blower sits solid on it (kind of hade to explain) but basically the to backet wont need to do any work, but I guess one at the front will put less stress on the bottem casting? Also what did you do to your engine for the blower like what cam do you run ect, and also been told I neg a fuel pressure regulater do you run one? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 29, 2012 Share Posted June 29, 2012 I've had a few engines with my set up. Basicly, the more you do, the better your chances of longevity. Get yours running to begin with, then you can look at making improvments. I would strongly advise running a big cam though. I got kelfords to grind me up a mystery stick to suit my needs. You wont need a fuel reg to run your set up. Your factory fuel pump might not be able to keep up though. Your carbs neelde and seat will only be able to hack around 3psi fuel pressure. If you fit a bigger pump to supply more fuel, then you'll need a reg to keep the carb from flooding. I think a pump like the ones found on Subaru Leones (The carb's ones) might be okay for your set up. (IF the standard pump can't supply enough juice) Quote Link to comment Share on other sites More sharing options...
Sparkle Posted May 3, 2013 Share Posted May 3, 2013 this is fucken choice man! Don't know why I haven't seen till now. badass. Quote Link to comment Share on other sites More sharing options...
Horse25 Posted May 3, 2013 Share Posted May 3, 2013 how much better does it go with the charger? Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 3, 2013 Share Posted May 3, 2013 It starts super well after meetings, I noticed. Especially when certain features are forgotten about. Hurr hurr hurr. 1 Quote Link to comment Share on other sites More sharing options...
427carguy Posted May 5, 2013 Author Share Posted May 5, 2013 how much better does it go with the charger? It goes really well with the blower the engine is standard 1300 at the moment but would easily beat my worked 1600, just got back from a trip to ashburton and it has no trouble passing cars. Quote Link to comment Share on other sites More sharing options...
