danger Posted July 27, 2011 Share Posted July 27, 2011 Wanna do my pontiac satin black. Guess options are black base with matte clear (fuckround) 2k black with matte agent (cant sit around mixed up or it seperates) Either of these options will be a bit of a fuckround considering I wanna paint in stages as its huge. Was thinking bout spraying 2k gloss black with GP instead of appropriate 2k thinner to dull gloss then giving a wet rub all over with 600? Any reason why this wouldn't turn out nicely and last? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 27, 2011 Share Posted July 27, 2011 It will not look very even if you get the matte finish by sanding, but it will be dull and reversible (i.e. when you want it gloss just buff it). Dunno about using GP thinners but. I don't recall the flattening agent separating last time I used it either, but it was a while ago Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 27, 2011 Share Posted July 27, 2011 Get PPG GMH Flat Black - its matte finish/cheap and its what I did my Austin in - paint has lasted 5ish years so far Quote Link to comment Share on other sites More sharing options...
governorsam Posted July 27, 2011 Share Posted July 27, 2011 have used fortec primer with good results. did my old merc in gmh black, (as above) cheap but very thin. rubs off after about 6 months. would have fortec anyday. used about half a litre to paint a 323 wagon i had. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 27, 2011 Share Posted July 27, 2011 Most primer is porous isnt it? The GMH painted pretty well and was thick enough on my car.. Hasn't rubbed off at all. That is (obviously) the first of 2 coats. It was sweet as and plenny thick with just 2.. Quote Link to comment Share on other sites More sharing options...
glen Posted July 27, 2011 Share Posted July 27, 2011 and thus the worlds baddest austin was born. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 27, 2011 Share Posted July 27, 2011 you will get the best result from the flattened clear over the black base Flat 2k never comes out as well as expected I find, I guess that paint KK has pointed out above is a Laquer based paint, shits old school now but it does give a good finish and is fairly durable (plus its cheap as shit). Also you know better than to use primer as suggested above Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 27, 2011 Share Posted July 27, 2011 I have a satin black non-porous primer that is the the goods for doing such things, I forget what brand it is but I'll find out where the fuck I put it and let you know if you like. The good thing about it being a primer is that if you get bored of the satin you can dust over in whatever colour you like. Edit: That said, K-trips product is the biz. Quote Link to comment Share on other sites More sharing options...
governorsam Posted July 28, 2011 Share Posted July 28, 2011 my bad, probably because i only gave it 1 coat after wiping most if the dirt off it... fitted in well with the rusty flames though... Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 28, 2011 Share Posted July 28, 2011 Serously fuck primer! a flattened laquer top coat is a minimum, even the non porus primer stuff is a shit top coat, UV fucks it eventually and it will end up looking ratty and crap over time. A laquer will last years, be easy to clean and is just as easy to paint over as a primer But anyway satin clear will give the best look and durability combo Quote Link to comment Share on other sites More sharing options...
danger Posted July 28, 2011 Author Share Posted July 28, 2011 I like 2k for the durability. I'll see how it goes. Probably end up being a pussy and doing a nice gloss anyway Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 28, 2011 Share Posted July 28, 2011 If you go 2k buy the flattening agent and mix it yourself, then test it until its sweet, unless your paint guy is a guru its best to do it yourself Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted July 28, 2011 Share Posted July 28, 2011 got a project thread for the pontiac? couldnt find it if you do Quote Link to comment Share on other sites More sharing options...
danger Posted July 28, 2011 Author Share Posted July 28, 2011 Nah havent bothered. May do someday Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted July 28, 2011 Share Posted July 28, 2011 i think you should do one massive thread with all your cars, would be epic Quote Link to comment Share on other sites More sharing options...
