rxtoy Posted June 13, 2011 Share Posted June 13, 2011 Did a quick search, couldn't find anything. Got some purple bubbled up crappy old tints on my crown, tried starting from a corner but its coming off real tough and crumbling rather than peeling. Any easy way to get it off? Cheeeeeeeers Matt Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 13, 2011 Share Posted June 13, 2011 sharp Paint scrapper and thinners? Or take some acid and go to sleep in your car Quote Link to comment Share on other sites More sharing options...
lou Posted June 13, 2011 Share Posted June 13, 2011 I guess you dont have to be too carefull as its not a painted surface, but I've used De-Solv-it Citris cleaner to remove vinyl graphics of a car before. It works really well at getting the stickiness off. Quote Link to comment Share on other sites More sharing options...
SloNLo Posted June 13, 2011 Share Posted June 13, 2011 try a heat gun/hair dryer to soften the glue/ film makes it peal easier Quote Link to comment Share on other sites More sharing options...
JoKer Posted June 13, 2011 Share Posted June 13, 2011 yup sit in the sun, get as warm as possible? Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 13, 2011 Share Posted June 13, 2011 Screw all the fucking about, get a razor blade and just cut it all off. If there's some on the rear window then maybe bother with getting it warm to peel it, otherwise who gives a fuck. Once you've got the tint off some thinners/acetone or the like should remove the residue fairly easily. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted June 13, 2011 Share Posted June 13, 2011 have had great success with water, just need a sharp blade to get a corner lifted and get a squirty bottle with water in it and away you go. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 13, 2011 Share Posted June 13, 2011 if its real gay cheap and old water wont work if you feel like taking the windows out then thinners melt them away nicely but if you dont take them out it will melt kill destroy your interior panels Quote Link to comment Share on other sites More sharing options...
crustywhip Posted June 13, 2011 Share Posted June 13, 2011 Screw all the fucking about, get a razor blade and just cut it all off. If there's some on the rear window then maybe bother with getting it warm to peel it, otherwise who gives a fuck. Once you've got the tint off some thinners/acetone or the like should remove the residue fairly easily. Normal razor blades will probably scratch the glass so be careful. De-solv it sounds like the best option as its easy to get. If you are able to spray the adhesive and then cover it again, this will give the best result of breaking down the glues. Tinters use a softer blade and soapy water for glass with out heater lines. There is some thing else but the name avoids me atm. Done this many times on customers cars when I worked along side a tinter. Quote Link to comment Share on other sites More sharing options...
Bling Posted June 14, 2011 Share Posted June 14, 2011 I used craft knife blades, took forever, wouldn't do it again! Quote Link to comment Share on other sites More sharing options...
rxtoy Posted June 15, 2011 Author Share Posted June 15, 2011 if its real gay cheap and old water wont workif you feel like taking the windows out then thinners melt them away nicely but if you dont take them out it will melt kill destroy your interior panels It is real gay, cheap and old. Will try the heat gun, or remove and thinners as the backup plan. Cheers for the replies Matt Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 15, 2011 Share Posted June 15, 2011 I've never had a razor scratch the glass, it's not as though you hack at it like the razor is an axe, you slide along with the glass. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 15, 2011 Share Posted June 15, 2011 I ruined a windscreen with a razor blade, I was going carefull as fuck too. Nobody was impressed Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 15, 2011 Share Posted June 15, 2011 Then I guess I'm magic/it's safer to avoid such results and take other avenues. As you were. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted June 15, 2011 Share Posted June 15, 2011 Gem blades are the go. Quote Link to comment Share on other sites More sharing options...
