Mr. Mainstream Posted May 21, 2010 Share Posted May 21, 2010 one of my mk2's has developed a noise at low speed in first have put it down to the drive-shaft bearing anyone got any experience/tips with changing them? i can just get new bearing from ford? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted May 21, 2010 Share Posted May 21, 2010 might be cheaper to get another drive shaft? Quote Link to comment Share on other sites More sharing options...
Raizer Posted May 21, 2010 Share Posted May 21, 2010 Not to mention its normally a cunt of a job to change them!! 2nd hand shaft ftw Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 22, 2010 Share Posted May 22, 2010 I recommend paying someone to do it! The old bearing usually shatters when you chisel it off which pts me off for a start. You can also get heavy duty plates that go behind the bearing as well, which is worth it too. Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted May 22, 2010 Share Posted May 22, 2010 When this happened when i first got the capri the garage ended up fitting a custom made 1pce driveshaft (was two piece originally) Was about $200 10 years ago, maybe more now. circle track engineering Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted May 22, 2010 Author Share Posted May 22, 2010 ive heard rumors through the winds that the 1.1L have a one piece shaft? in that case it would be best to hunt one of them down? if they fit 16-hundys anyone in chch got a driveshaft? gt_chrome - you are so lucky to have a Capri is it WOF'ed? id love to have one. mini mustangs Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted June 6, 2010 Author Share Posted June 6, 2010 Well i managed to get a one-piece from a wagon and get it in the ghia no problem wish i knew the diff plate was different first thou the bearing in the 2-piece was well used is there any disadvantage running a one-piece? i mean you should be able to get better suspension angles with a 2-piece right? but the 1-piece allows for a lot of travel at the gearbox end with the shaft so i dont know if worth getting the 2-piece recon'd or not Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted June 9, 2010 Author Share Posted June 9, 2010 Any Advice? Quote Link to comment Share on other sites More sharing options...
Bombsquad Posted June 9, 2010 Share Posted June 9, 2010 If the car has an irs rear end then two peice is possibly better, if its live axle then 1 peice is the go. The only thing you might have to do to go to one peice is fit a driveshaft loop.\ I dont really think it makes fuck all difference apart from the cost. Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted June 10, 2010 Share Posted June 10, 2010 I always ran One Piece in my old fords, Less weight, less rotational mass, less complicated. Just watch the Diff flange..size and pattern changes between Mk1 and 2 Quote Link to comment Share on other sites More sharing options...
Beaver Posted June 10, 2010 Share Posted June 10, 2010 dont know about escorts, but on my mk2 cortina, i had to space the gearbox down a touch after i lowered it, as the drive shaft was touching the body just behind the gearbox haha Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted June 10, 2010 Share Posted June 10, 2010 ^ Mk2 Escorts are guilty of this also, sucked my carpet through the hole it bored one nite, mean! Quote Link to comment Share on other sites More sharing options...
Beaver Posted June 10, 2010 Share Posted June 10, 2010 haha thats mad! mine knocked on a lateral chasis rail/brace thingy. a few washers and some longer gbox mount bolts later its all good. Quote Link to comment Share on other sites More sharing options...
mk2escort Posted June 11, 2010 Share Posted June 11, 2010 Off topics but Mr. Mainstream whats up with that grill on your black escort is it made of metal and where did you get it? Quote Link to comment Share on other sites More sharing options...
Mr. Mainstream Posted June 11, 2010 Author Share Posted June 11, 2010 i think its just a factory ghia grill. soon going to convert to round headlight anyway, pm me if keen on it. Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted June 11, 2010 Share Posted June 11, 2010 Must be bro-painted, Ghia has an anodised alloy surround and caps on the middle bar either side of the badge. Quote Link to comment Share on other sites More sharing options...
