samii Posted November 23, 2009 Share Posted November 23, 2009 i don't see how this can be possible but is by some way the turbo lag affected by the size of the intercooler. just a guy i know is after an interooler but he doesn't want a big one cause of the lag. surely having a bigger intecooler wuld allow more air to be cool so therefore more air for turbo and more power? but would it really affect the lag? thanks, samii Quote Link to comment Share on other sites More sharing options...
Simon Posted November 23, 2009 Share Posted November 23, 2009 The larger the intercooler the more volume / mass of air it holds. This air has to be sped up and re compressed every time the turbo spooles because the majority is let out by the bov. If there is more of it but the turbo is the same size, its going to take longer for the pressure to become even at the inlet manifold. Yes, over size intercoolers make a difference to lag. Does that sound sort of right steve? Quote Link to comment Share on other sites More sharing options...
palmystar Posted November 23, 2009 Share Posted November 23, 2009 could possibly effect response due to there being more volume to fill between the turbo and the throttle body. edit: as said above Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 23, 2009 Share Posted November 23, 2009 yes. i went up in size considerably from stock supra (JZA70) to R32 GTR and it made a noticeable difference. Quote Link to comment Share on other sites More sharing options...
Bling Posted November 23, 2009 Share Posted November 23, 2009 Most of the front mounts out there are probably for looks anyway. I'm sure there are cases wheres its needed, but i'd say more would be fine with smaller better suited coolers. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 23, 2009 Share Posted November 23, 2009 yes bad enough for me to wish i hadnt swaped on my gtir inter cooler was a bit bigger but masses of big pipe added to the volume Quote Link to comment Share on other sites More sharing options...
DodgySam Posted November 23, 2009 Share Posted November 23, 2009 yes bad enough for me to wish i hadnt swaped on my gtirinter cooler was a bit bigger but masses of big pipe added to the volume On mine i went down in size on mine...it made it so there was almost no pressure difference. Big shiney fmic's are all bling and just for the "look at me I have a turbo car" factor. The main reason i changed on the gtir was for ease of getting to the plugs etc. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted November 24, 2009 Share Posted November 24, 2009 Does that sound sort of right steve? You made me lol Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 24, 2009 Share Posted November 24, 2009 yes bad enough for me to wish i hadnt swaped on my gtirinter cooler was a bit bigger but masses of big pipe added to the volume On mine i went down in size on mine...it made it so there was almost no pressure difference. Big shiney fmic's are all bling and just for the "look at me I have a turbo car" factor. The main reason i changed on the gtir was for ease of getting to the plugs etc. mine was hidden and not for bling bling the car was dressed down to an x1 1600 spec had to use front mount as the bonnet didnt have a silly bulge but i ran a 3" pipe from the intake to the side of the intercooler which i should have replaced with a smaller one Quote Link to comment Share on other sites More sharing options...
DodgySam Posted November 24, 2009 Share Posted November 24, 2009 yes bad enough for me to wish i hadnt swaped on my gtirinter cooler was a bit bigger but masses of big pipe added to the volume On mine i went down in size on mine...it made it so there was almost no pressure difference. Big shiney fmic's are all bling and just for the "look at me I have a turbo car" factor. The main reason i changed on the gtir was for ease of getting to the plugs etc. mine was hidden and not for bling bling the car was dressed down to an x1 1600 spec had to use front mount as the bonnet didnt have a silly bulge but i ran a 3" pipe from the intake to the side of the intercooler which i should have replaced with a smaller one Ah yeah I ran 2.5inch piping. I love the gtir bonnet...I converted it into a air intake for the air filter in the end tho...worked well good. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 24, 2009 Share Posted November 24, 2009 still cant beat 250atws in somthing that looks like your nana should be driving (bonnet, spoiler and badges said it was not a gtir) Quote Link to comment Share on other sites More sharing options...
RT Posted November 24, 2009 Share Posted November 24, 2009 Definitely makes a significant difference. People who put massive shiny 'look at me' front-mounts in their car usually regret it if they care about performance. (which most don't) Same as going ridiculously big on the exhaust. Quote Link to comment Share on other sites More sharing options...
Simon Posted November 25, 2009 Share Posted November 25, 2009 Same as going ridiculously big on the exhaust. Doesn't matter so much for turbo car though? You see those drag cars etc that don't even have an exhaust off the turbo. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 25, 2009 Share Posted November 25, 2009 full 3'' system made a missive gain on my car Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 25, 2009 Share Posted November 25, 2009 Same as going ridiculously big on the exhaust. Doesn't matter so much for turbo car though? You see those drag cars etc that don't even have an exhaust off the turbo. yes it does. drag cars have fuck all to do with a "usable" engine. they do their job very well, but put those engines in a street car and you will soon learn that exhaust sizing on a turbro is very important. sheepers. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 25, 2009 Share Posted November 25, 2009 Is 3" a good size? Quote Link to comment Share on other sites More sharing options...
fuel Posted November 25, 2009 Share Posted November 25, 2009 Is 3" a good size? For anything 2.5L and upward yes, probably not for under 2000cc and also probably not necessary for 2L cars either. Depends what horsepower numbers you are chasing I guess. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 25, 2009 Share Posted November 25, 2009 Is 3" a good size? For anything 2.5L and upward yes, probably not for under 2000cc and also probably not necessary for 2L cars either. Depends what horsepower numbers you are chasing I guess. mine only cost me $100 from BSE so i compromised also this is starting to look like the turbo thread Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 25, 2009 Share Posted November 25, 2009 2ookw 2L? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 25, 2009 Share Posted November 25, 2009 Factory Celica one I'm using is 3" in and 2" out but I'm running it reverse to that. Have benefit of less than a metre of intercooler piping total though Quote Link to comment Share on other sites More sharing options...
