Alistairs Isuzu Bellett
Toucan
independant rear end, but it more resembles a swing axle arrangement like beetles and skodas use more than usual IRS - has coil springs in the trailing arm as well as a transverse leaf going from one side to the other (possibly for anti-roll?)
  • Replies 207
Did someone put the leaf in upside down?
Will have a look, you mean the leaf that spans the back yeah? Suppose if they naturally have a little negative camber that could do it.
Looks good.
Independant rear right. Does it drive ok/no bent axle? Maybe someone has put a longewr axle in it for some reason giving camber.
Yeah drives fine, both rear wheels have + camber no matter what wheels are on it.
What phil said, its swing axle so camber depends on height.
Should be about 6 coils in the rear with a colour code of either white yellow or red an a single transverse leaf.
Did you roll it back and forth after you let it off the jack, cause that just looks crazy
Yeh but like I said brew, it was the same with stocker wheels, just more accentuated with bigger reyums on there.
Will check out spring/leaf combo later.
