twosmoke Posted May 11, 2008 Share Posted May 11, 2008 . Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 11, 2008 Share Posted May 11, 2008 Sigma Steels are 5.5" wide. Probably your best bet in all regards though. Easy to find, look pretty good, wide enough to fit a good tyre Quote Link to comment Share on other sites More sharing options...
twosmoke Posted May 11, 2008 Author Share Posted May 11, 2008 . Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 11, 2008 Share Posted May 11, 2008 6.5 fits under the guards, I have 14x6.5's on my one, with around +5 offset. Quote Link to comment Share on other sites More sharing options...
durty Posted May 11, 2008 Share Posted May 11, 2008 Sigma Steels are 5.5" wide. Probably your best bet in all regards though. Easy to find, look pretty good, wide enough to fit a good tyre Cheers. Its looking like that may my best bet. Fairly sure 6.5" wont fit under the guards, so was going to go 6" if possible. Is the ford pcd 114.3 as well? Maybe something the escort guys use could fit? fords = not 114.3 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 11, 2008 Share Posted May 11, 2008 Factory wheels off mark 2 toyotas might me the go.... Allan Quote Link to comment Share on other sites More sharing options...
kpr Posted May 11, 2008 Share Posted May 11, 2008 yeh 6.5" fit easy. ive had 7" rims on mine with 205's on them Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 11, 2008 Share Posted May 11, 2008 Jesus pies... Get some 14x6.5s under there, will look choice/kprs Starley Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted May 11, 2008 Share Posted May 11, 2008 i run 14x6 with a +15 offset with 185-60-14's... it only just clears the guards and there lipped but mine is sorta low so if your running standard length struts you could run more neg offset Quote Link to comment Share on other sites More sharing options...
twosmoke Posted May 12, 2008 Author Share Posted May 12, 2008 . Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted May 12, 2008 Share Posted May 12, 2008 heres a pretty crappy pic but you might get the idea... (i also have longer lower arms in the front for camber) Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 12, 2008 Share Posted May 12, 2008 Sigma steels are by far the best looking factory steel that is easily obtainable. Or you could go to elite wheels an get some D window centres put into some centreless bands but that would end up quite expensive Quote Link to comment Share on other sites More sharing options...
twosmoke Posted May 13, 2008 Author Share Posted May 13, 2008 . Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 13, 2008 Share Posted May 13, 2008 Mates brother has 195s on a Starlet with Sigma Steels. Looks a bit balloon but not tooooo bad Quote Link to comment Share on other sites More sharing options...
twosmoke Posted May 14, 2008 Author Share Posted May 14, 2008 . Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 16, 2008 Share Posted May 16, 2008 Grab these viewtopic.php?f=15&t=14214 Be lighter than steels an will looks mean Quote Link to comment Share on other sites More sharing options...
twosmoke Posted May 16, 2008 Author Share Posted May 16, 2008 . Quote Link to comment Share on other sites More sharing options...
