CaMpylobacter Posted December 11, 2007 Share Posted December 11, 2007 Hello Chaps, I've got some rather interesting suspension bushes which I need to replace, but they're unavailable to purchase from the local shopkeeper. I also want to make an engine mount. For both of these tasks, I need some liquid urethane. Does anyone know of a source for this? It needs to set to be able to take a reasonable amount of pressure. thanks in advance huzzah Quote Link to comment Share on other sites More sharing options...
Goat Posted December 11, 2007 Share Posted December 11, 2007 Dads got heaps of polyurethane Probably way to brittle (sp?)/shit Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 11, 2007 Author Share Posted December 11, 2007 yeah. needs to be fluid as I can't push them into where they're going, and still have them tight. they'll just cut themselves.... weird. I've thought of urethane like windscreens are glued in with but I'm not sure how it'll go hmm Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 11, 2007 Share Posted December 11, 2007 I think you can buy it at some hardware shops from memory I know i have seen pics online of honda guys beefing up there mounts with it Quote Link to comment Share on other sites More sharing options...
shavenYak Posted December 11, 2007 Share Posted December 11, 2007 Yeah I'm pretty keen to give that a go (pouring new engine mounts) - otherwise, what are some good places to check for new ones? called stink repco and the "Mount Shop".. are there any others? guess I could try suzuki as well.. Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 11, 2007 Share Posted December 11, 2007 Yeah I'm pretty keen to give that a go (pouring new engine mounts) - otherwise, what are some good places to check for new ones? called stink repco and the "Mount Shop".. are there any others? guess I could try suzuki as well..BNT Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 11, 2007 Author Share Posted December 11, 2007 rofl. yeah that's the adhesive style one. such a rangimod thing to do. I was gonna inject urethane into the bottom mount of my pooj before last track day coz it's fucked from oil leaks. Decided it wasn't worth the effort so jsut ran as is... have been up til now as a complete mount though I don't wanna use like 3 tubes of that shit lol. wont hold up methinks. I've thought of using a solid bit for the mount and turning it down in a lathe but yuh, pouring is gonna be a little more reliable/give better longevity. Stocks is across the carpaprk from me so I should ask them. the welly guys aren't as good as the dudes in auckland though, sadly Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 11, 2007 Author Share Posted December 11, 2007 Yeah I'm pretty keen to give that a go (pouring new engine mounts) - otherwise, what are some good places to check for new ones? called stink repco and the "Mount Shop".. are there any others? guess I could try suzuki as well.. afaik the only ones you should bother poruing are round encapsulated ones. alto mounts should be a piece of piss to get though. suzuki still do them. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted December 11, 2007 Share Posted December 11, 2007 yeah. needs to be fluid as I can't push them into where they're going, and still have them tight. they'll just cut themselves.... weird. I've thought of urethane like windscreens are glued in with but I'm not sure how it'll go hmm Common practice for Honda folk to fill engine mounts with windscreen stz urethane when they crack, and seems to do the job sweet! See if you can contact a guy on Toyspeed "ronio73" and ask what he uses, he makes moulds up and makes some fairly mean urethane mounts etc. Quote Link to comment Share on other sites More sharing options...
shavenYak Posted December 11, 2007 Share Posted December 11, 2007 afaik the only ones you should bother poruing are round encapsulated ones. alto mounts should be a piece of piss to get though. suzuki still do them. yeah just called Suzuki, they've got two on the shelf for $138 + gst each.. I guess that's pretty standard price for OEM stuff.. was hoping for cheaper though. BNT go through Autolign Mt Wellington (09) 5742290. Talked to a chap there who machines Nolethane ones for around the $100 mark. Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 11, 2007 Share Posted December 11, 2007 theres a place right by where miniman works, that casts new mounts etc, just give them your old one and tell them how you want it done and they make it. Forget the name of the place though Quote Link to comment Share on other sites More sharing options...
thminiman Posted December 12, 2007 Share Posted December 12, 2007 will try have a look tommorow, am normally asleep when i roll to work, not suspension tech? or john brookes ltd? Quote Link to comment Share on other sites More sharing options...
V8Pete Posted December 12, 2007 Share Posted December 12, 2007 http://www.superhonda.com/forum/showthread.php?t=204274 Might be of interest. Keen to try also Edit: Pwnn003d Try: http://72.14.253.104/search?q=cache:CuB ... cd=1&gl=nz Quote Link to comment Share on other sites More sharing options...
kpr Posted December 12, 2007 Share Posted December 12, 2007 devcon flexane 80, i think the stuff is called. got it from paykels (sp?) from memory. 2 pot stuff, mix it up like resin. poured engine mounts for my fwd starlet years ago. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 12, 2007 Author Share Posted December 12, 2007 toit. yeah one of the i can't put in the oven to cure, or near that kind of heat, so the devcon stuff would be choice. mean, dude. cheers. engine mount I'm keen to experiment hard, thoguh Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 12, 2007 Share Posted December 12, 2007 nah its not suspension tech, he gets stuff done through them though Quote Link to comment Share on other sites More sharing options...
shavenYak Posted December 12, 2007 Share Posted December 12, 2007 Just called ITW, the supplier for Devcon, comes in a 454g bottle of liquid or in a putty form. Can get it at Auckland Engineering Services in Beaumont street (down by all the marine shops in Auckland) for trade price $130. Guy said they only do two hardnesses 80a and 90a, the Devcon 80 is 84 Shore A scale, so it's gonna be pretty rigid compared to the 60 that the honda guy used. A 454g bottle would be enough for two sets of mounts all round for my car, so maybe one of yous is keen to go halves? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 12, 2007 Author Share Posted December 12, 2007 your mounts will be square and shit wont they? v8 pizzete was gon' fund out bout his shit today. see how that goes. I'm k33n to go halves for an engine mount though if that falls through. Quote Link to comment Share on other sites More sharing options...
shavenYak Posted December 12, 2007 Share Posted December 12, 2007 I've got the lower support mounts that are just flat, squarish ones, but then I got three upper ones that control the twist, and theyre round ones, like this: haven't actually had a good look at the lower ones, I think I can get them from repco/autolign/bnt, but if I'm gonna have urethane left over I might as wel try to make them as well. Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 13, 2007 Share Posted December 13, 2007 Fuck, just solid mount the mighty 3cylinder. Quote Link to comment Share on other sites More sharing options...
