eke_zetec_RWD Posted January 6, 2006 Share Posted January 6, 2006 studs are easy to change and they defently should be changed when wheels are changed to alloys becos the wall is thicker so less thread to hold wheel on. john bates which is around da corner from fortec wil have sum or can get sum over nite. i think you need 6 full turns of thread. Quote Link to comment Share on other sites More sharing options...
davidian Posted January 6, 2006 Share Posted January 6, 2006 hes an eatass. i used to run 13x7½ and it was all good. oh well palmside sells longer ones for like $8 ea Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 6, 2006 Share Posted January 6, 2006 it has nothing to do with wheels zise or anything, its to do with the thickness of the wheel where the studs go through Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 6, 2006 Share Posted January 6, 2006 exactly, steel wheels are stronger therefore thinner at the stud hole then alloys, these studs are designd for steel wheels Quote Link to comment Share on other sites More sharing options...
atropine Posted January 6, 2006 Share Posted January 6, 2006 yeah there were only 5threads holding it.. which aparently is no good fortecs gotten ahold of some toyota studs which are about half an inch longer i think so its all good.. now its planned for on the trailor tomorrow night.. but any problems arising in the cert or warrant again will stunt that obviously... Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 6, 2006 Share Posted January 6, 2006 DELETED Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 6, 2006 Share Posted January 6, 2006 So, back on topic, how is the 1600 rebuild going? Quote Link to comment Share on other sites More sharing options...
escortman Posted January 7, 2006 Share Posted January 7, 2006 just chuck sum old rims on or borrow sum or woteva 4 the cert and wen its dun put them bac on? easy as fuc Doesn't work, you are not allowed to change from the wheels your car is certed with without paying out to get the car re-certed. Cars have been stickered for this by the cops. Callum wat how many ppl do u c in done up cars running around on factory rims so y wud cops pink/green sticker cars but im not sure on the cert tho Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted January 7, 2006 Share Posted January 7, 2006 aslong as they look the part... u shudnt hav much 2 worry bout. i honestly dont think cops wud worry about the rims on astros car..... Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 7, 2006 Share Posted January 7, 2006 DELETED Quote Link to comment Share on other sites More sharing options...
escortman Posted January 7, 2006 Share Posted January 7, 2006 on the lvv cert page all that is said about wheels is that cant stick out past body and tyre size can not hav more than 5% increase in rollin circumferance Quote Link to comment Share on other sites More sharing options...
esky boi Posted January 8, 2006 Share Posted January 8, 2006 Yea thats right, but when a vehicle is certed the wheels are measured and the size is noted down on the plate. So putting on different sized rims to what is stated on the plate is illegal.. stupid really, but yea. Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 8, 2006 Share Posted January 8, 2006 on the lvv cert page all that is said about wheels is that cant stick out past body and tyre size can not hav more than 5% increase in rollin circumferance Yes, but if you car get's certified to run a particular type/size of wheel and it's stamped into the certification plate, then if you're found to be running a different size of rim without ammendment to the cert plate, then you're screwed. Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted January 8, 2006 Share Posted January 8, 2006 the only thing i nknow of that would make u have 2 get ur mags certd is if they are more than 2 inches larger in diameter. if this is the case i dont c any problems with the mags on it.... so if he swapd some other ones on 4 the cert then they will b the same size as standard (look like 13's)..... thus meaning no cert problems and can change them back over no worries. Quote Link to comment Share on other sites More sharing options...
esky boi Posted January 9, 2006 Share Posted January 9, 2006 Yea but the size is noted down on the cert plate (weather they need to be certified or not) So changing them after the cert will mean that whats shown on the cert plate wont be whats actually on the car. Will probably never get noticed anyway, but if it does then the car will probably be stickered I guess.. Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted January 9, 2006 Share Posted January 9, 2006 even if the mags on it r a different size then stated on the cert plate, it wont matter if they dont need 2 b certd, so it cant get stickerd if theres nothing illigal about it. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 9, 2006 Share Posted January 9, 2006 DELETED Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted February 6, 2006 Share Posted February 6, 2006 well put widebody Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 6, 2006 Share Posted February 6, 2006 fortecs gotten ahold of some toyota studs which are about half an inch longer i think so its all good.. Toyota do some real long studs. Would be thinking the thread is differant tho so might need to change ya wheel nuts also. Imperial to metrix styles Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 6, 2006 Share Posted February 6, 2006 gotta make sure theyre from the HC 1300 though as the lower compression 1300 wont be helping you much. 1100s are even better. Pretty sure when i researched it the 1100 pistons was way to high compression. Also dont think there is much luck of getting the lc piston. Think that was more from the english versions. Quote Link to comment Share on other sites More sharing options...
