mk2_escort Posted December 6, 2005 Share Posted December 6, 2005 hi guys just wondering if anyones knows any good sites on rebuilding the sierra engine. i will be doing my own conversion in2 my mk2 escort soon and got myself a cheap sierra. dad and i think its best 2 rebuild it before working the engine so any info or tips would be much appreciated!!! i am on a budget so just simple things like pistons and rings , rebore, gaskets etc etc. please help me. Quote Link to comment Share on other sites More sharing options...
davidian Posted December 6, 2005 Share Posted December 6, 2005 have you ever rebuilt and engine before? if you need a site you probably havent. i suggest you dont do it but hey thats just me Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 6, 2005 Share Posted December 6, 2005 What exactly do you want to know? How to put pistons in? bigends? How to gap rings or what? These are all general so just search for engine rebuilding or maybe a library book. Pretty much all the other shit you do is sent away to do. Like rebore, crank grind etc. You say you are on a budget. I would pull the engine down first and check the bore. I would try and save money in the piston department. They are the most expensive part of rebuilding the pinto. They could be fine! I would rather rebuild everything else in the engine rather than buy pistons that arnt fully needed. Also some things arnt avaliable in NZ for the pintos so will need to be ordered from UK. Hope something there helps. Quote Link to comment Share on other sites More sharing options...
Eskorted Posted December 6, 2005 Share Posted December 6, 2005 my best advise is get a haynes manual... i rebuilt mine as my first engine and the haynes was my bible! simple engines realy... as long as u got some patients it should be sweet Quote Link to comment Share on other sites More sharing options...
TygerTung Posted December 7, 2005 Share Posted December 7, 2005 Engines are SO simple, you won't have a problem, just get a book out the library on one or buy one, it tells you everything you need to know, you won't regret it. Quote Link to comment Share on other sites More sharing options...
Toucan Posted December 7, 2005 Share Posted December 7, 2005 Haynes manual all the way, helped me through my first engine rebuild Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 7, 2005 Share Posted December 7, 2005 Yea man get a haynes manual, they go into lots of detail and have good pics. You can pick up secondhand ones cheap as. Quote Link to comment Share on other sites More sharing options...
davidian Posted December 7, 2005 Share Posted December 7, 2005 Yea man get a haynes manual, they go into lots of detail and have good pics. You can pick up secondhand ones cheap as. i got my autobook mk1 book in the mail yesterday! bad! goes into heaps of detail down to illustrations of some Fonzie dude rebuilding auto trans Quote Link to comment Share on other sites More sharing options...
Hemi Posted December 7, 2005 Share Posted December 7, 2005 yea re-building engine is easy if u follow the book and do everything properly , i reckon the hardest part would be the timing belt/chain i always get owned on those things Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted December 8, 2005 Author Share Posted December 8, 2005 hey thanx guys. i dont need 2 know how 2 do most things, its more what are the most important things to do and that i should b spending my money on. i need a haynes manual 2 must look on trade me i think Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 8, 2005 Share Posted December 8, 2005 there was one listed today i think Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted December 9, 2005 Share Posted December 9, 2005 IF you want to know where to spend your money give us an idea of how much you have to spend on the engine and we can let you know whats gona give you the best value for money, most power for your dollars etc Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted December 9, 2005 Author Share Posted December 9, 2005 ok il probly b spending no more than around $1400 Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 9, 2005 Share Posted December 9, 2005 Dam you could do abit to a pinto for that, you're doing the all the building yourself I take it? For a basic rebuild.. ie. new bearings, gaskets, rings etc its about 350 ish all up.. then youve got another grand to play round with so yea Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 9, 2005 Share Posted December 9, 2005 I cant member how much RT wants for that head he has (could suit turbo from memory) but it could be a good start. OR If you had a grand left over you could. (chances are you wont if you have to replace pistons and rebore, crank grind, etc.) - Buy a 1600 pinto head. Get it worked a little with larger valves and take some metal out of the chambers to slightly lower compression. maybe spend $500 there on a cheapish port polish. - Buy a cam from kiwicams or the likes for round $100 - Extractors from the net for maybe $50 or from coby for $250ish - lighten flywheel a little - rejet 32/36 carb could be $5ish. That should be good for round 130hp I would say depending on the port job. Quote Link to comment Share on other sites More sharing options...
v3k Posted December 9, 2005 Share Posted December 9, 2005 Good luck and go hard, just follow books directions and fuck the naysayers I have a book that is called "how to rebuild your 1.3, 1.6 & 2.0 OHC FORD" If you get stuck or want a cross reference, pm me and I'll scan pages for you (if you are lucky ) just not the whole book. Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted December 10, 2005 Author Share Posted December 10, 2005 well thats good 2 no lol. yeah should b able 2 do most of the work ourselves. after the rebuild the mods i have in mind are extracters, exhaust, carbs (hopefully twin 40's sideys), port and polish head, cam (including rocker arm set and valve springs). i realy want 2 stick with the 2l pinto as i want lots of torque on tap . so yeah im just looking 4 advise on rebuilding at the moment (as the car isnt running) and weil look at working the engine later... Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 13, 2005 Share Posted December 13, 2005 well thats good 2 no lol. yeah should b able 2 do most of the work ourselves. after the rebuild the mods i have in mind are extracters, exhaust, carbs (hopefully twin 40's sideys), port and polish head, cam (including rocker arm set and valve springs). i realy want 2 stick with the 2l pinto as i want lots of torque on tap . so yeah im just looking 4 advise on rebuilding at the moment (as the car isnt running) and weil look at working the engine later... Do you mean you have $1400 just to rebuild the engine? In that case you might as well use new or second hand forged pistons as thats a lot of money to rebuild to standard spec. Or throw some balancing in there with it. Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted December 13, 2005 Author Share Posted December 13, 2005 put it this way... iv picd up a sierra 4 $200, iv got at least 1400 2 spend on it 2 get it going (not going at the moment), and giving the engine a decent once over, not going overboard, and then working it. dont need 2 go forged, but down the track i want around 150hp atw would be nice Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 13, 2005 Share Posted December 13, 2005 You could get that much power out of it pretty easily with 1400 to spend man.. depending on how much you're intending to spend on the rebuild that is. If its a decent motor, ie the bores / pistons arent shagged then you wont be looking at much more than 300-350 to rebuild it.. Quote Link to comment Share on other sites More sharing options...
