Everything posted by Eskorted
ha thats pretty intense for a pinto. should look that up to
mint thanks ill have a search! good luck with the ca bro! let us kno how it goes
far out 9s in a scort would be crazy im keen on doin 12s tho give alot of people stick! u got that CA/SR dont ya? wouldnt mind goin sr. easy cheap power i spose
thats some good info there meth. im goin to get some prices. i need power. but dont think ill do it in my 4door mk2 lol would be a mint sleeper tho
well i do have a cam that can only be fitted with the bearing towers cut in half and bolted back on to get the lobes through, nah N/A would be way to undrivable. i have a cossie bottom end so should handle a turbo/supercharger better than sierra bottom end. but even then ill need to sus a dam good port job. maybe section a spare 2L head and learn how far it can be ported and where.
lol tis all good. o well its goin alright for now. time to rethink my quest to 200hp. prob supercharger....
must be a diff grind cause mines 285 in 280 ex intresting.
fr32 from camtech $285 deliverd. its a brand new billet cam. 285 inlet 280 exhaust. they throw so far the valve springs almost bind. its strange tho cause my mates mk4 corty has been driving with 1.6 head for about 6months now. could also be the fact that his rings are shot... and no pinto heads almost neva crack. well i have never seen one to date. maybe i need to stop worring about getting alot of power out of N/A. cossie bottom end and supercharge it.
nope. neva needed to before. the starter motor wasnt strugeling so couldnt of been that high.
well we took it off and discoverd this... after 17 hours of fucking around port work and shiz. definatly wasnt there when we where working it. cause i was cleaning it up good and would of seen a crack that big. the 1million dolor question is what caused it? could it of been on its way? with the extra comp and port work ect would it of just helped an existing problem just get worse? o well so you learn. next time i will definatly get it crack tested before i do anything! Thanks very much for all the input! cheers guys. ps meth those fr32 cams idle awesome ay. very choice cam!
thats the mani after 20mins at 2g. the water pump is only about 2 years old ay. we had it running just before and the water in the radiator is bubbling something rediculous.. oil is full of water to. such a simple problem yet it has hundreds of fixes...
ke20 & cam: yea she has to 12" electric fans bolted to the radiator. and we hooked up oil gauge to it. never got hotter than over half and oil was minta mikunu u raise a good point. maybe what i should of mentiond is near the end of the breakin in sesion the manifold was glowing bright orange. we thought wed run the standard one while breakin it in. now the temp guage wasnt hot but could the head of goten to hot with the manifold get so fucking hot??
nah shes all tuned up perfect. i done static timing on it and had the carby recond. would u have to use the head bolts from the 1600 motor?
good point. we did have a flat edge on it and it seemed fine. could it of bent once we put it on? the manifold was glowing after 20mins at 2grand to break the cam in. could it of gotten so hot that it warped?
Hey guys Ive got a 2L pinto in my scort and desided to get a 1600 head got a light port job done and got a fr32 cam with new rockers valves ect. now 2 head gaskets later it keeps blowing and pours water into the third cylinder, consistantly the same cylinder. also should note that both have done it after about 20-30mins of running. so ive tried the 2L gasket and 1.6L gasket and both wont have any of it. I gues the main question is. wich is the correct head gasket to use and what els could cause this??? Many thanks in advance! Don
im not 100% sure on the crossmembers bien the same. i used the original holes... didnt have to drill anymore. was urs manual?
I got one. but some one is bound to say that it wont fit. can sus a pick for you if you want. my esky was auto if that makes a diff. and i used the auto gbox xmember on my 5speed, just mounted it backwards. Don
shit that is a good price for your mate! some eskys on TM gettin pricy now ay.
oh sad. life goes on eh. you get a decent amount for her?
who pulled your chain?
Very sad to hear her go bro. Bet ur gutted. Why may i ask? time to move on? new project?
hes right. it is in the domain. at the top. might come ay. got a dodgy alternator tho, so will see how it handles with night cruising tonight.
how much you prepared to pay for one? i could sus one out for you.
It might pay to check if fuel pump is working and nothing blocked. Just unplug the fuel inlet off the carb, have something to catch the fuel in. There should be 2 healthy squirts every revolution. Well thats what i can remember from my haynes manual.
