Taistorm
Everything posted by Taistorm
You can get a 'good enough' keychain of depinning tools off wish cheap as chips.
Awesome build man! Turned it super clean.
Man this build just blows me away Everytime I read through it. On another level!
DABUZZ'Z 1971 MAZDA CAPELLA RE + New 74 RX4
Taistorm replied to dabuzz's topic in Project Discussion
How good man! I saw Choppers post yesterday on insta, looks so sweet. -
I'm pretty sure @OSM Garage specializes in torque wrenches. He might be able to help you out/sus you a deal.
Give Luke at Advanced Seals in Silverdale a call. He might be able to provide other alternatives that might help the issue.
Could just knock the studs out so it sits flat and use a softish punch to whack em on easy or prop it up on something between the studs.
Has he looked at rebuilding it? I'd take it to AES off paramount drive in henderson. Probably cost more than rock auto but much less than $500
Not sure what the seals are like but with most seals if you can get a sample/dimensions/bring the housing and shaft in your local seal shop will probably have something. Advanced seals in Silverdale are awesome to deal with, also the likes of ABD are also on to it.
Cheers for that man, will have a read through and forward it on. Might be worth having them speak to another accountant for other opinions/advice as it sounds quite similar. Definitely gonna keep an eye on this thread as you're doing an awesome job!
Are you able to pm me with further details in regards to the taxing side of this. My parents are going through a similar process but (selling one section to me for under market value and selling another for full price) for a recent subdivision (only 2 sections). They've been advised by an accountant that the sale is included as a second income/income tax, addition to their standard earnings so the sale price less costs to do the development will be the amount they're required to pay tax on, pushing them to pay 39% on that final figure. Interested if there are other ways they can go about it (not trying to avoid tax but this is essentially their retirement safety net so the more they can keep from this the better obviously).
Sounds like a charging issue now haha. I'd check the alternator belt and make sure it's tight, then jump it and test it's charging voltage.
Yeah definitely sounds like battery. Check the battery posts/terminals to make sure they're clean and tight. Also check the main earth lead and terminals as these sometimes get missed. If these are sweet, jump start it and see if it goes. If it does then check to see if the battery is charging right (should be around 14v while running, if not could be a faulty charging issue or even a loose alternator belt). Also if you can, remove the battery and take the battery in to your local repco or garage and ask them to test the battery (high load test), this will determine the batteries life pretty quickly.
Check voltage drop across the battery and also at the starter and also voltage to both main 12v lead to starter and Exciter wire. If these are bad then either your battery or your starter could be cooked (could also high load test your battery if you have access to a tester to rule it out). As you've mentioned as well also check terminals and wires (as well as Earth's) if these are good bridge the starter wires and see if it starts, if it does then it's probably Exciter wire/ignition wire related. If not common symptoms like the starter solenoid just free spinning or only throwing out and not spinning, or not throwing out at all means that your starter motor is probably gone.
Damn that's cheap
Chopper at Choppers auto body shop in Riverhead can custom make coilovers to suit whatever application with everything required to pass cert.
All tech in wairau usually carry pump kits. Alternatively if you're just after seals to suit, remove the seals and take them in to advanced seals in Silverdale, they're awesome to deal with and cheap as.
After 2 hours on the rotisserie and the internal temp to just over 60 I took it off, wrapped it and let it rest for about 20mins. Removed the string and cut it up and damn, not too bad. Juicy and tasty as, sticky on the outside. Made a quick sandwich for a snack and will be using it in noodles tonight. Probably freeze some of it for future ramen.
- 14 replies
- 17
We've got some mates coming around tonight so decided that we'll make some Soba noodles, and thought about doing some chashu pork on the rotisserie to break it in. Picked up about a kg worth of pork belly, had a crack at rolling and tying it up (one end had more meat than the other and I didn't want to trim it). I salted the meat and let it sit for about an hour. After I made a Japanese style marinade using soy (light and dark), mirin , sake, rice wine vinegar, sesame seeds, garlic and ginger. Let it marinade in that for about an hour and a half then setup the bbq. It's been on for about 45minutes since that last pic and tbh it probably doesn't need too much more. Will keep you guys posted shortly.
We had people coming over for a late lunch so we had to get cranking asap. Let the paint sit for 10 minutes then quickly fitted the vents and assembled it for another burn off. Only had about 2 hours to burn it off and cure the paint before I needed to get some food on. Got it up to about 500f for about an hour and a half the tried to drop it off in preparation for cooking. Random home kill rolled beef roast I found in the freezer. Approx 3kg gave it a blackout rub. Really wanted to get it on the rotisserie but it was too bloody hot to fit it up haha. Got the temp down to 350f and threw it in, couldn't really wait for it to drop anymore. Ran it at about 350f for 2.5hours indirect with stout in the driptray. Combination of Kingsford briquettes, applewood and some Manuka we had lying around. This is absolutely winged and rushed, for the first cook and I had no probe for internal temp. Let it sit for about 20mins wrapped in foil, when served it was about medium, slightly rarer in the middle so not too bad considering (forgot to take pics). Held temp well, I think if I start off with less coals (i.e not doing a burn off) I'll be able to get the temp right where I want it and also vent/damper controls will work a treat. I'll look at cutting the cooking grille so it's 2 piece for access loading up coals. Chur
My Mrs gave me a hand with the prep and paint. Cleaned with soapy water then a few wipe downs with acetone. After that we brushed on a few coats of pot belly black, decided to go with the stuff from the tin as previous spray can efforts turned to shit and flake off easy. 3 coats later and it looks like this. Disregard the handle, it is just makeshift for now so we can take the lid off easy and it's fitted with tekscrews. I'll make another later.
Burn off the other night went well. Got it to 500f and it held there for atleast 3 hours without adding any extra fuel. Left it going when I went to bed. Had a look in the morning and it looked like this... Emptied out the ash and gave it a good clean to prep it for seasoning and paint. Just used olive oil on the inside as that's all I had and Mangawhai shops are shit to go to this time of the year cause of all the jafas and northern bass homies.
Upper and lower racks sitting in place. Then set it up for it's first burn off to kill off any nasties from the paint and stripper. I added a few more similar size chunks of Manuka and got it cranking. So far it has been sitting at 500f for the last 2 and a half hours with no extra fuel. Seems to be going well enough for something that owes me about $130 and about 10hours. Yeah a Weber GA is only $150 but this is far more rewarding. I might give it another burn off tomorrow morning then I'll be seasoning it, throwing some paint on the outside then throwing in a rolled beef roast. Keep. As to see how it turns out. Will get a picture of the rotisserie tomorrow. Chur
- 14 replies
- 15
Quick cut of pine dowel for the handle. Will redo this later, just screwed it on for the time being. Vents fitted up. There are 2 x 100mm vents on either side at the bottom and 1 x 125mm vent at the top left. I had to give them a few light taps with the hammer to make them a bit stiffer for adjustment.
Quick once over with the flapper disc. The inners were painted in what looked like a red oxide primer, being the inner I thought it would be best to use a relatively organic paint stripper (found an orange and alcohol based stripper at Bunnings). Turns out the paint stripper was average as, went over it 3 times and had to hand sand the shit out of it. It's done now... I also cut notches out of the grille mount for more cooking space. Looks way better though. And the El cheapo Bunnings thermo gauge mocked up.
