cletus
Moderators
Everything posted by cletus
  1. I think to chrome a wheel properly the rim has to be removed from the center so all the areas of the wheel can be polished properly , I dunno if it then gets welded back together then chromed or chromed then welded the guy I work for is doing something along these lines for his current build, I'll ask him Bumper replacements in onehunga is the last place I heard was good for chrome but that was a while ago
  2. On the turbo setup in my VG I had the hot side piping done in the extreme stuff, they do a ceramic coat (the white/silver ) then go over that with the black, that was pretty good On my current vehicle I just had them coated in the black, but I think it's either a bit thin or not up to the heat of a turbo setup as some of it has gone rusty in places
  3. If it has methanol in it it is considered a fuel system so has to comply with all of the fuel system requirements, which none of the typical water methanol injection systems that you can purchase comply with. However if you put a sticker on the tank saying for water only then it's just a water tank and there is no rules If you wanted to be 100% legit then you could build a system as per the fuel chapter in the CCM and it would pass cert
  4. Just some ideas for you because I like to help
  5. some sort of device to work with canbus light wiring?
  6. The guy building the jalopy engineering front ends did a really nice job, hopefully the new owners keep up the same standard
  7. they can pass, requires design approval, and the geometry is less than ideal i cant remember if its ht-hg thats one of them but there is one of their front ends that has a really short top arm which on paper is a cock up especially if its set at a higher ride height
  8. There are some certifications that are approved here, that don't require lvv cert, but it's quite specific, usually only applies to things modified in Europe or Australia, and its production run vehicles like campervans, disability vehicles , gvm upgrades. Has to have the correct label on it
  9. Imports from Japan with coil overs has been the 'bread and butter' work for me , for ages They were the jobs that were actually profitable, and kind of subsidized the more complicated work This work has dried up a lot over the last few years so the price of other stuff has had to go up to cover the time it takes
  10. There are no lvvta rules, and the wof requirements are very minimal for light trailers, by drawing a design that's not in crayon you are already ahead of most trailer makers
  11. Nope. Courier sent a pic of the bin they left it on, saying gps showed they dropped it off at the right address I sent them a picture of my bin, to show it was in fact not dropped off at my address, and could they tell me what address they dropped it at But they would not I spent a couple of hours walking around trying to see where it might have ended up, trying same number house a street over, or a street not far away with a similar name etc Cunts
  12. Haven't done anything yet, still waiting for part to arrive and I've been too busy at work to think about it
  13. If you remove or shorten the roll center spacers that might fix it? That will lower the wheel in relation to the tie rod end
  14. That will completely fist the geometry though You would need to raise the inner joint pivot the same amount, or it would cause a large amount of bump steer
  15. it can get murky. in an ideal world= the car is certed for a, b and c mods the cert is done properly the first time now has d and e mods added a certifier only has to assess the new mods, the others are covered by the previous cert. you get a new cert and carry on with life however, especially with the new photo based system, this is often not that easy, and a large can of worms can be opened, often a recert can turn into a fucking nightmare due to previous certs being done poorly, things being missed the first time, the old plates not being big enough to fit everything on, the expectation of what should be certified on a car changing over time, people adding or changing stuff that fits within the limited description that fits on a old style tag and even just trying to figure out what was acceptable at the time when it was first certed. this all takes time, emailing back and forth with lvvta etc it always takes me longer to do than just starting a new cert on a freshly modified car for example, the welded caliper brackets on @dabuzz car, if i was re doing the cert, normally that would be a no go, cant do that, but it already has a cert for disc brakes on the rear,so i can just write down "previously certified" however i dont know if the previous certifier went to lvvta to get an exemption because it was already done or did he not notice at all or did he notice and choose to ignore it or has someone changed it since it was certed so ive got to take a photo of that mod for the new cert, and say yep thats good, its on the cert with my name on it, so everyone that looks up that cert from here on, sees that i did the cert so to cover my arse, id have to go to lvvta and explain the situation, and get the OK from them, this might take a while because they would likely recall the paperwork and see what it says it might say that there was a NDT for the weld and it was welded with a low carbon rod to a cast steel bearing housing and there was a exemption given at the time, in which case it is ok or it might just have a tick in a box next to 'car has brakes' in my opinion if you are changing the calipers or are unhappy with it, just cut all that shit off and make a bracket that bolts on to the ends with the calipers you want
  16. Yeah just disconnect it and block it off and run it It's not a common problem but easy to check and cross off the list
  17. White smoke can be brake fluid , check its not leaked into the booster and is chewing on that ?
  18. Vacuum pump is under the injection pump by the looks of it, the pen is pointing at it The vacuum pump looks similar to the one on the back of the alternator, it will have a fitting to attach your vacuum hose to
  19. Yes I am in that general location Can pick up for you
  20. Boss has a 428 with triple carbs It's not actually that bad on fuel if you just tootle around on the middle carb
  21. cletus
    Hilux diff Q
    Yes it is a 4 pinion, you can see the ends of the pins x4 in the carrier on most diffs, the carrier is the same offset and the difference is in the gearset, ie the ring gear might be thinner but the pinion gear is a bigger diameter to change gearing. Which doesn't really make sense in your situation, a 4.8 would have a smaller diameter pinion, not bigger I would think I am not a hilux diff expert though so someone else might know 100%
  22. Aluminium is OK if its a reputable aftermarket manufacturer If you were cobbling something together yourself then there may be more questions
  23. @johnny.race has a bit to do with diff stuff
  24. anyone else using the Waze app? its kinda handy, basically its like google maps but you can update things on the the map yourself, the main advantage is you can see where there are crashes, police, speed cameras, etc
  25. Ah right. I guess you could have a look at examples of OEM axles or hubs and see what thicknesses they have in that area, and use that as justification it's OK?
