Yowzer
Everything posted by Yowzer
  1. How do you buy a saw and not use it? The 1st thing I did when I got my hands on one was chop the roof off a car just for fun. And then realized I chopped all the trim I wanted to save in half as well..
  2. I can most likely sort a good deal at blastakarts. They're a lot more lax there than the other places, last time I was there we had a few beers there before hitting the track which they had no problem with.
  3. 1,000kg is fucking heavy for an ATV, but that's what the website says
  4. Coupe lyfe
  5. Seems pretty out of it that they can run sans AFM from factory
  6. "Looked" is very deceptive. Have you seen what was under that paint? They packed the rust holes with tinfoil..
  7. Too advanced can cause knocking / pinging, so you may need to run 98 etc unless it is way too far. Too retarded will cause a lack of power, and excessively retarded can burn up the exhaust valves. Try advanced on 98 and see if you have any issues.
  8. I am liking the sounds of this but I don't know if I can commit to it yet
  9. Next on your list is a G4 Link.
  10. Also, this. http://www.trademe.co.nz/Trade-Me-Motor ... 365739.htm These things are tiny / similar size to KKs lighter I think the CT9s are even smaller, and pretty cheap.
  11. Come on man, what the hell is he gonna do with a brown lighter?
  12. Not necessarily, most cars with mechanical fans run viscous couplings, so the fan can effectively freespin and doesn't really do much. Although older cars did have solid mounted fans that did run all day long, they had flexie blades that flattened out at high speed and again didn't really do much.
  13. Yowzer
    D.I.Y gaskets
    This ball peen hammer trick sounds pretty nifty. Might give it a try someday (without knowing what the fuck I'm actually meant to do with the hammer)
  14. Last I recall the adjustable ones at Supercheap were $60. That was awhile ago. Was using them in both my Avengers and they were all good. Otherwise, you can get thermostat switches from Jaycar for dunno how much even though I work there. There's one in 80 deg, looks like this $6.90? Have one on my brothers avenger, cabletied to the bottom coolant hose (can't remember what temp it is though) It seems to work not too badly. It'd be better contacting metal as opposed to a rubber hose though.
  15. It still spins, although somewhat reluctantly, so I'd say the bearings are pretty fucked. Still hit 5psi at moderate throttle before I disconnected the wastegate actuator anyway. However it did spool up a lot slower than normal, and sounded fucking horrible while doing it. In any case, it's fucked.
  16. Dunno. It's still on the car at the moment, but it is very audibly fucked. Make an offer I guess. Probably won't have the replacement sorted for a few weeks though That is it there. Not overly exciting.
  17. If you want, I will soon have a CT20 available that makes all sorts of cool noises. Will be ideal for your application
  18. Can't say on the ratios, however the shift points will most likely be a lot higher to suit the petrol engine rev range. Depending on the g/box, you can slacken off the kickdown cable so it changes earlier, or there may be some other way of adjusting it that I don't know about.
  19. TBH I would not even consider getting it repaired, unless you really can't find a new one, or have some form of sentimental attachment to your current one. Anything involving the voodoo that happens inside an auto costs megadollars. Especially at Marshalls. Converting my cressida to manual would have cost considerably less than getting the original auto repaired when it shat itself. However I ended up sticking another auto in it, which also shat itself a few years later.. Moral of the story; Autos suck. Get a manual.
  20. Fuckin' link it already. Road tune it on the way down to Palmy
  21. Lush. Departure time will be?
  22. Thursday for me, dunno when, but sometime. Yah.
  23. Slightly off topic, but is your golf the slammed one with roofracks and rusty front guard? [edit] Ignore that, it is.
  24. Yowzer
    Head bolts
    Yah, go ARP if you want it to last a bit longer. Otherwise just mash the old ones back in, with a bit of superglue around the gasket to seal it up. How can you not get a full set? That sounds rather strange..
  25. Mine snapped in half.
