Local Area
Waikato
wickmyster's Achievements
Advanced Member (3/5)
Anyone have the part number for this or have a spare one? There are to many variations on ebay and I am not sure which one is compatible :/
Bingo with the worn cover...well actually part of the block, have to have a hole filled in and a new camcahin is on its way for $200 including tensioners and seals etc....want to hart to get the old on off either
I know there is a lot of hate for these engines on this forum, but I love them, that is why l I have just purchased my second Sierra which has a carbed 8V DOHC, but it is leaking a lot of oil from the front somewhere, the car is stuck 5 hours away at my parents house, what is the most likely culprit...the crank seal or the oil pump or???
Noob question, how do I get a link etc to work in 250 2v
wickmyster replied to wickmyster's topic in Tech Talk
What is the best set up for a crank trigger? Also, is there any benefit from running a wasted spark set up?/How much harder will it be to get it running a normal firing set up, I dont mind running 6 coils as I was planning on coil-on-plug set up if I can.- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
I am thinking of trying the cam angle sensor from an AU on my non crossflow, as they seem to be able to dropinto my dizzy hole without much modding.- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
Ok, think it it time to get a spare motor and start playing- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
OK. I am only running my 250 2v 6. How to I put a cam position sensor on my old motor? and what's is the best way to get RPM signal from the crank?- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
I want to know what controls the timing on this thing http://members.iinet.net.au/~mikejh/XP.html and thid thing http://members.iinet.net.au/~mikejh/502XC.html- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
I already have a full SVI system from a dual fuel BA. I want to use it in my Coupe just to be different, but it will have better power and economy that and carb LPG set up like my E-gad BA has:/ I might have to hunt for some instaltion instuctions for my kit. But can anyone answer my intial question?- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
thegreatestben, do you run an O2 sensor etc to get the LPG kit to run?- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
Ohh that would be a bonus, I was contemplating doing efi as well...to dual fuel it, though I may just have it suck air through the carb I mice big throtle body would be pretty nice, get a bit more of a roar out of it.- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
Heres a pic of the controller http://postimg.cc/image/6wqpbxxsh/- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
Anyone? basicly, how can I make a link, motec,megasuirt run on my 250 2v (1972) motor?- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
My goal is to run a SVI LPG system on my 250 2v, but I need an ecu for the ecu that came with the LPG kits to get the spark pulses from so it known when to squirt the gas in. So how do I get this sorted? Do I need to get a crank trigger sensor or something, I have already for an electronic dizzy, can I marry the two together? Any ideas/help will be awesome.
- 20 replies
- stand aloneecu
- falcon
(and 3 more)
Tagged with:
Sounds like it is coming from the throttlebdy mixer...sounds like it is coming from the speedo when I floor it, car still goes well. Just cut out my cat converter as it self destructed and was rattling around.https://www.youtube.com/watch?v=-t_2xzpUwlE&feature=youtu.be
- e-gas. LPG
- help. noise
(and 1 more)
Tagged with:
