Everything posted by tortron
Maybe check the timing isn't too far advanced. Maybe check that the mechanical advance isn't stuck Vaccum leaks too maybe
Does the choke actually work
To power the mask till you strike the arc, then it's solar. It should be recharging itself
I was told red/the permanent one
Ever had the welds crack, maybe due to different expansion rates? Maybe not a problem when the weights go in from the side, some v8ss throw them out and is suggested to weld a bit of steel over the top jnstead, but I think this is when they put them in the circumference of the Web rather than the side
Malory metal /tungsten alloy. Loctite and then stake the edges in
Re used oil Pukekohe supercheap takes up to 10L containers Repco Pukekohe also has them and takes up to 20l (what I had, and also they don't lock them)
If you have a good enough scan tool you should be able to check to see if everything related is in spec. Something g that's adjusted to 120% for example is likely to be sticking for example. You might have air leaks and it's trying to adjust on the fly, and then when it's in the next position that airleak doesn't effect it, are the spindles something that wears?
You a cock or a union greaser?
Is it a minarelli type?
Lost some of the U bolts on a shit road after getting ducked around by a useless seller, so have a bit of a bent guard. Many ratchet straps held it together for the ride home Very fixed now and out doing legal things
Gearboxing is a time honoured tradition
Are you able to use a clear tube off a drain fitting on the bowl to measure the float level on these carbs? Handy when there's no data available, fuel in the hose will match where it is is the bowl
Buy from ebay an oh woops they lhd
King Country Crusade 17th 18th 19th November 2023
tortron replied to alfalfa's topic in Lower North Island Region
Is anyone driving / trailering from Auckland? -
Sr241 or bust
Maybe usps related
Literally a future classic I know a guy with a fun one, and a totally stock for future collectors one And my neighbor had just got an apparently spring less, muffler less one too
