Everything posted by tortron
Repco morrie rubber was impossible (after enough complaints they changed the profile apparently and now it works) Warming the rubber may help you over the edge. I ended up putting a few dabs of sealant under the trim and holding it in place before moving to the next section
https://rockboatmarine.co.nz/products/snap-fasteners?variant=31610477576330¤cy=NZD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=CjwKCAiAgeeqBhBAEiwAoDDhn4C_ICjrkpQJAck6ibbwQ9gs3LYQNjd4AcUu09z440AHVjvzvGqy2BoCsH0QAvD_BwE Heavy duty snap
Probably it will be at this point there will be some pushback Plenty of ute bull bar tyre poke enthusiasts out there
tortron replied to h4nd's topic in Other Projects
I thi k you could combine an old bbq and an old lawnmower for an effective machine -
How's that for project creep
- 243 replies
King Country Crusade 17th 18th 19th November 2023
tortron replied to alfalfa's topic in Lower North Island Region
Hopefully not east cape soggy! Don't forget the chainsaw and some strops -
The switches get ahit/corrosion in them. Pull apart and clean and all G for thr next 10 years. Let's power through enough to go down, but too much resistance for the extra work of going up Also I have this for you
You might have to pull finger on that
Holden hothouse green for a period correct build
Are you set on yellow? https://totalbodyshop.co.nz/products/copy-of-2k-green-1lt-s16?_pos=1&_sid=2044f4932&_ss=r They also have a tin of yellow enamel. Something about rustoleum never sets and is full of oil. So might have to strip it all off if you over coat it
Few beersies before spraying the lawn?
Gona be in some far away land then unfortunately -
You are reading it correctly that if it allows moisture or dirt in its a fail
Should be a public service Kia kaha team of 5millio.on the road to zero
Have done it to I think every vechicle with a cowl I have owned. It's real easy when everything else is rusted out so you start from base level lol
Shhhhh don't look at it It will be leaking from the rusted out seam in the cowl. V.lame to weld up
Bought another trike Probably a triang, tuff? Or some variant of that Very well used, front tyre and spokes are stuffed. So good candidate for a trailer
Modern sideskirts etc are held on with male/female push in clips and then 2 bolts at the ends Might I suggest Nissan wingroad parts Rivnuts are always good too
Get him to watch his training video, kia kaha road to zero 4.38 is the bit Rust is not corrosion damage. Corrosion damage is pitting, heave, bleed, a hole. Minor surface rust like a stone chip is just rust. Best to send his inspector number off to ensure he is up to date with his training
