Ned
Everything posted by Ned
  1. What a good day Cheers Neal, and everyone who attended!
  2. Walters road is the ane that rubs between southgate and mill road. Go to south gate, and by the roundabout turn into Walters road. Go over the the tracks and keep going. Then a roundabout, keep going. Then there will be some fields and car parks etc
  3. I'll be there have no family, but I'll bring an Evan if that helps?
  4. txt me about coming to grab it, or i might be coming your way Friday potentially? Not home tonight, but should be home tomorrow evening, or can leave it out for you if you want it asap. 021 413 423
  5. i have a big corded beast that will drill a hole through the center of the earth if you want it to? In Ellerslie/Remuera.
  6. Steeb, i saw this and made you a knight rider scan bar. Please fit it to the car ASAP! not even joking
  7. I vote north island
  8. always 5 teeth past the sensor when engine is at TDC so ECU knows whats up. Doesnt matter where the sensor is.
  9. Allan, I tried PMing you but getting some gateway error when I go to my messages, so this will have to do. You still looking for a cheap 3 way fridge? Saw this, thought of you: http://www.trademe.co.nz/a.aspx?id=1214900924
  10. +1, looking good!
  11. Did you get a China man to design that for you? Doesn't look too bad from a first glance. Couple 'wtf you doing there trev?' Moments but none that scream out anything super important. Keen to hear how you got about getting that made, and some idea on what it cost would be cool if that's ok? Just curious is all. Having a sweep, or program option, or maybe just a serial port to set the values would be cool so you can automate it. When you start logging fuel pressures and things, you might want all of that to be logged in one place? So you know what the settings of the injectors were when you go back through the logs. Maybe having that separate from the controller could be cool though, so get the logger to log the duty cycle and frequency etc separate as a sanity check in the log, just in case something happened and it leaves the injectors on too long due to some weird internal glitch in the code or something. Just thinking out loud
  12. Hey Denham... If you make it so the legs mount back on the bottom if the truck, you can keep the while thing off the ground except the wheels, so def no snakes then... And you can just move it a bit if you want to reposition during the day. That's what the big off road teardops do, all awnings and things clip backnonto the teardrop, not the ground.
  13. Same deal. In the garage again now
  14. You wanna look for real short bursts though or fuel pressure rising, so log it with your controller for sure. different FETs in different controllers is negligible. Injector dead time is often measured in mS or at least very high uS. FET switching time is measured in nS... quite a bit faster, and the difference between most FETs is sweet fuck all... plus a lot of them use VERY similar hardware inside them anyway. I would make my own rig to test injectors. You just need to build a variable frequency drive with a decent FET on the end. Will be pretty easy to do on an arduino or something if you feel like fiddling around for a couple weekends. And that way you have complete flexibility as well, and can make it do whatever you want after that
  15. Attention :: Ellerslie/Remuera Let's kick this off... I will be attempting to fit an new radiator, replace some rack ends, replace some injectors and potentially fit a clutch switch for my launch control to the Starlet. Haven't been in the shed for a while, but there is (likely expired) beer in the beer fridge, and I'm sure we can grab a pizza or something later today if anyone is keen to come hang out. Even having someone to pass me the 12 I left while I'm under the car would be ace No experience necessary Expected shed time: midday today Ellerslie/Remuera area Ned 021 413 423
  16. Pretty easy, PM me and I'll see what I can sort out for you if you want.
  17. Can I come have a look? I need somewhere to store one of the vehicles so I have room to work on the remaining ones. Coming to have a look is really just a formality, I'm 99% in, but feel I should come round and check it out before signing on the dotted line... Ned 021 413 423
  18. Are you looking for someone to store stuff, or someone who wants to spin spanners in it?
  19. the heading even says boring stuff, why would you read that!? The internet produces new cat videos every hour that you can watch rather than reading the boring section of an oldschool post... come on man!
  20. i dont know what that means... but i didnt bring any friends so i'm safe i guess. Will be there hopefully the turnout will be better than last month. I guess they were all put off by fancy walking? (i might be making a giant ass of myself as i have no idea what im saying)
  21. Sounds normal to me...
  22. Ooh, that looks pretty!
  23. Where were all you guys?!
  24. I have some extractors but they run through a shit exhaust, so that and cooling is on the cards, and wanna so something else so decided a cam would be a good idea
