durty
Everything posted by durty
  1. //oldschool.co.nz/index.php?/topic/34643-how-to-add-pictures-to-the-forum/
  2. Choice as Volvo v70 http://www.speedhunters.com/2013/07/a-station-wagon-unlike-any-other/
  3. Man the boilers on these are sexy looking, kind of a shame they put covers over them and hide them away. would look so cool all polished up
  4. Guess they have mates that will wof it for them or they swap tails each wof or FTP
  5. Look to be about 300 - 350 pounds jesus
  6. Just a note. Glass isn't a liquid http://io9.com/the-glass-is-a-liquid-myth-has-finally-been-destroyed-496190894 http://dwb.unl.edu/Teacher/NSF/C01/C01Links/www.ualberta.ca/~bderksen/florin.html
  7. how cheap for shuvit? what does it need?
  8. Get a sedan, seems like it would be easier? I'm so sorry
  9. This thing is ka pai Even says it on the rego
  10. Make sure you get the High def version not the standard definition version
  11. That is to do with your extended arm. if you could somehow spin at least 10-15 cats just around your wrist and made sure to keep your wrist in the same spot they would work themselves out to be balanced
  12. when driving slowly can you hear the bbs rolling around in the tyres?
  13. You seem dead set on using s13 gear so not sure why you asked the question. I personally think that following allans home made coilover guide would be cheaper and easier //oldschool.co.nz/index.php?/topic/29372-seedy-als-guide-to-home-made-coil-overs-56k-u-r-fucked/
  14. This is amazing, so keen to be passenger for some rolling burnouts in this thing
  15. So exited to see this on air
  16. will have a dig in the shed, I had a couple left around that I had robbed bits off when rebuilding them. Will see if I have enough to make a whole one
  17. So keen to see this all put together
  18. Grind 2mm out of the jacking points? Or chuck 50 psi into the rear tyres
  19. That is awesome news
  20. Handles unscrewed in the middle so the wire can be replaced if it snaps etc, could probably make the same thing for cheap enough I would think but effort makes buying one much easier. Was pretty cheap with bnt hook ups. Not sure what brand it was but it had to be ordered in overnight
  21. I have used a thing that was pretty much piano wire between two handles. Got it through bnt Took it slow and steady and won the race
  22. Could you replace those side bits and do it a bit more like this?
  23. set up a youshop account and get them shipped that way, will be like $30
  24. Yes it will need a cert, just because the previous owner was lucky/knew someone who would turn a blind eye and give it a wof doesn't mean anything really
