Everything posted by Bangbug
You can buy the personalized plate that matches your black plates then roll with them, much $$
Nobody has ripped on you for having a 316ti. Not sure if I'm proud or sickened. I'm sorry I have nothing helpful to add except throw a 2.8 in there
^seconded Vinyl for the win
Yep. Buy a turbo one
Skip the Bombays and come through hunua
Only if it's solid Curtis Mayfield on 8 track the entire way
4g61? 1.6?
Good write up Thanks very much for taking the time. I think to your final 3 questions you'd have different answers had it been for something you cannot buy, or cannot afford to buy but can do so this way? So to underline your problem, 1999 Subaru Lancaster wagon. We're all super pleased that the visit to VTNZ went well, I'm pretty sure all of us cringed when we read those dreaded capital letters!
When I worked at autoterminal I'd see tonnes of em come in with them on, saw plenty on yards for sale too. And you know some dipshit is going to drive around with them on until they've fallen apart!
I've been looking at similar things. And I've found for every opinion there is a counter opinion. Dang it. It's hard to even get a grip on which way opposing opinions are swaying! Read the guff on POR 15 and then priming that and spraying over bed liner etc. And then I've decided that I'm pretty much going to leave it all the fuck alone for now because underbody prep sucks Do you have kevlar wear plates in the areas of high abrasion?
Bmw v10. Eats oil. They carry oil around with them. Dafuq new engines?
new school question - removing superglue from car paint
Bangbug replied to BlownCorona's topic in Tech Talk
I would have cracked out a razor. #lifeontheedge -
Kumeu Hot Rod Festival - 16-17 January 2016
Bangbug replied to pusherman's topic in Upper North Island Region
I didn't see the T!!!!!!!!!!!!!!!! NOOOOOOOOOOOOO!!!! I wanted to sit on my couch again -
sheepers 1977 (i think, could be 76) Toyota Celica TA23
Bangbug replied to sheepers's topic in Project Discussion
Proper chrome wrap vinyl is HELLA EXPENSIVE as well. I shouldn't say such things but PAINT ALL THE THINGS!!!!! -
Anyone have a motorcycle I can borrow for a week?
Bangbug replied to Llama's topic in Upper North Island Region
More likely to borrow an old lady than a motorcycle!!!! Haha Last time I lent my bike it came back in pieces! And the piss wizard didn't cop up a dime to get her fixed up. Hope you nab a ride, temperature is good atm, my soft contis are working really well! Good bit of rain after the main crowds to wash the roads down too Happy motoring! -
Ok, the weight in a e30 is slightly front biased (6%) so I'd say with a wagon it'd be brought back closer to 50/50 due to the extra weight in the rear. 1300kg So 325kg/corner BUT those bags over strut thingies I don't know how to work rates/volumes out for because they've got a strut in the middle! (affects volume but mostly for rates but it's end cap size in the calc, could guess but bugger it, they must have rates somewhere online) Lift charts are super helpful if you can find em. I have a full set for my bags hurrah! If you know the weight (325kg or so ~720lbs) ADD some for you and your gear/missus/mates and then the height (measure) and then look at the chart you will see the approx psi you'll need. BUT...... (damnit) you'll want to work out any motion ratio as well. This means it's the distance your car raises vs the amount your bags raise. A quick lookup shows Rear (0.67) front (1.06) but don't quote me! So if you're looking at the lift/height chart and see fuck all lift height in the rear don't stress the bag will actually need to do (1/.67) ~1.5 times the lifting so you'll need more psi to bump it up to a respectable level If you're lucky you'll have a ballpark spring rate at X height. You'll find the different rates at different heights too. And now you can see how much air you'll need to lift front ride height to "up" for those driveways and from "parked" to ride height. Just plug in your details to my earlier calculation. That'll let you know how many psi minimum you'll need in your 2 gal tank. Hopefully you're not as confused as I now feel
Sounds like yours was a proper dog of a pump spencer If my crude scribblings are close to correct you can imagine plugging sheepers specs into the equation. 5 gal @ 150psi gives you many grams of air (I find it a little easier to think of grams instead of volumes as what does 5 gals of 50 psi potential (above bag inflation psi) actually mean?). If...... WHO asked the question again? ...... would like to put in their bag specs that'd be good if they have them worked out we can all do a little maths and perhaps get more learned. If they don't have their specs we can work them out if they have spring rates existing or vehicle corner weights and bag height requirements. Or back to front if they have the bags they want.
It's too late and hot for this but I'll give this a jam. Min to max lift of biggest bag of mine to 100 psi (lots psi, max lift) 1.6L per airbag x 4 = 6.4L Lets say 100 psi all round @20 degrees (9.37g/l) Tank pressure 200 psi @20C (17.54g/l) 17.54g - 9.37g = 8.17g / 9.37g/l = 0.87L (per 100 psi drop per litre tank volume) 6.4/.87 = ~7.36 L (1.94 us gallon tank would balance out bags and tank at 100 psi) Or am I waaaaaaaaay off
If you want to look at fill rates etc. http://www.viaircorp.com/480C.html#tabs-3 Down the bottom right is the specs, rates etc. If you had a light car and a small tank the 480 can run 1.07 CFM @ 100 psi (500cc/sec) so even if you ran out of tank puff the pump is no slouch. But 2 pumps and a bigger tank is always better, MORE IS MORE!!!!!!! I'll be starting with a single 480 and a 3 gal tank. Can always add more right Get your calculator out!
Post back here if you grab em and they can close the thread. Everyone wins
Yes, these are not in the correct location but they totally ARE in the correct location because you sicko's may not look in the "For Sale" part and I want you to get your eyes on these. I spied two twentys down the scrappies one is pretty rotton one is pretty sweet If you're after something else to do during the xmas break, pick both these up and make one lovely one. PM for deeets I'm not selling em but I'll point you in the right direction.
I have some. How much you need
Good point. Thankfully heat doesn't conduct through steel. Heat the whole thing. Don't heat it red hot! Grab the coefficient of expansion ofF Google just for giggles. File mushrooming first and formost as mof and trips said though. Solid advice. (As said above)
