Shakotom
Everything posted by Shakotom
  1. It's this pretty much M12 is 12v and yup, is quite small. Uses their 'redlithuim battery' which is the small one Battery size depends on Amp hours. I've got one like in image that is either 2 or 3 amp hour (both are the same size), but there is a bigger one, which I think is a 4 or 6 amp hour battery which is similar style, that has the same top but a square bit on the bottom that protrudes forward a bit Difference isn't power, just how long it'll last. One of the joys of lithium is that I'll will deliver max power all the way till batterys flat Unlike my snap on gun which because it has a NiCad battery, is mint when fresh off charger but torque output drops abit as charge depletes
  2. I have a snap on 1/2in impact gun It's okay, but only reason I own it is I won a snap on voucher through Holden and my air one died around the same time. No torque limiting function. But If I was paying with my money, I'd purchase a Milwaukee M18 1/2in one. One of the other techs in workshop and the tyre shop at work have one, and I don't think they've come across anything they can't undo They also have a torque setting on the large ones (1 and 2) I think there around 900? For the skin, two batteries and a charger I own the Milwaukee 3/8th drive m12 fuel one. I have nothing but praise for it. I use it everyday and it's so lush. I think it's rated to 120nm, but it won't undo wheelnuts. Most other things- bellhousings/other mechanical things are with in its grasp Has a torque limiting function aswell. I think that cost me around $350? For the skin, two batterys and a charger. And since purchasing that, have also got the m12 ratchet and a torch to go with Also battery life on m12 stuff is sweet. I think I charge them about once a week? Takes like 45min to charge
  3. I have an American car! Also, thread jack, If you like American cars, there's a burger/Parkup night at Carl's junior in takanini on the last Thursday of each month started recently by my hot rod club (manukau rod and custom) Should be 28th of this month. They have a 'no jappers' rule because hot rod barrys. But Merica! F**k yeah! Ima start a thread on it actually
  4. Hey Pete https://www.carthrottle.com/post/brace-yourself-someone-has-stanced-a-ferrari/
  5. Someone's gonna need to bring sand to soak up all the leaked oil
  6. Disappointed that wasn't a skid vid
  7. You need a dozen frosty pigs to go with the waving cat
  8. DOES IT HAVE A WIPER SWITCH??? Can I has if so??? Also, 10 speed, I have the half a swing axle bug sitting on my lawn. I need to pull body off to strip gbox/clean frame to turn into trailer at some point Let me know and you can use the frame horns to mock when if you want also
  9. Man I like that Honda tank
  10. Meh. Wheels suck. Needs 16s
  11. I took VW to hot rod meet once Got stuck on speed bump leaving and because of that ended up doing a burnout in front of hot rod barrys trying to get off Had a fresh hair cut No cert though... Job out look looks okay maybe? /ling
  12. There is a distinct lack of burnouts leaving caffeine and classics....
  13. Man that was good I got a lawnmower and some aerial flags.
  14. ^that should be enough to pay for some insurance.
  15. Man that must be a rush!!!!!
  16. Shakotom
    It looked cooler slammed out back than high That's my 2c anyway. Keep up the progress!
  17. Purple FA50s been running mint Took it to dromeageddon because Im a bitch with no fab skills so I couldnt build a dronebike. Go hard or go home right Also took this POS and spent more time trying to keep the kickstart in place/had to go buy circlips/making it run/lost drive/gaveup Also, Remember my other Fa50? the blue one.... It sort of fell apart.... Untitled by OR4NGE, on Flickr and the paint disappeared Untitled by OR4NGE, on Flickr but its now registered at least! Untitled by OR4NGE, on Flickr
  18. Just saw this on the tard and pined hard
