AllTorque
Moderators
Everything posted by AllTorque
  1. Is each side getting the same fluid pressure at the same time. You can get pressure gauges that screw into the bleeders, but are probably a bit tricky to find. Is there one line from the master cylinder that tees off to the two front sides?
  2. You can get these for safety https://trademe.co.nz/1207860239
  3. Sorensin used to work for the Surgery. Ask him what he thinks of the place.
  4. It wouldn't be too hard to wire it up so both fans come on for cooling and AC.
  5. If the wrecker is sub-euro parts world in Porirua, hit me up.
  6. Can't get ribs at the beach. I like 1841. Cheap jugs too. I like jugs.
  7. Would if I could, but I can't. Will be doing the hula. Have a good wagnats warm up.
  8. I took this to Hawkes Boes. Bloody dash lights died again. They flick on for a bit if you wiggle the switch. I guess I should have got the $25 headlight switch from RockAuto instead of the $10. Headlights were amazing on the night time drive up. Especially the high beams. So that's nice. Pics taken by some special people.
  9. Even thought it's a lot newer, have a look what Jason The Bogan did on his chev. //oldschool.co.nz/index.php?/topic/36713-jasonks-79-chev-caprice-hearse/ It should be similar front end to your Ponti and has been certed. Start a build thread. Keen to see more pics.
  10. This one is pretty close, Terry. http://www.fenixautoparts.co.nz/index.php?route=product/product&path=64_85_764&product_id=2084
  11. We'll be passing through between 5:30 and 6:30 tonight. Should be able to squeeze them in the wag.
