yetchh
Everything posted by yetchh
  1. Fuck yeah bro! Love chevells.
  2. Ruh roh!......
  3. Hah thanks, those comments are much appreciated... In my mind it seems like I'm doing an average job except for the occasional win.. A bit like my golf. If we get a good price for it, the whole thing will have been worthwhile.
  4. This also meant I could now finish the entrance. I needed to extend the threshold on either side and originally was going to get piece of cedar like the threshold, cut the front off in line with the facings and epoxy the other bit of cedar on that included the extended ends. Cfb factor took over and I just epoxied some mac extentions on, sanded then and painted the whole thing karaka Finished the last of the cladding and then oiled the deck. Used the same stain as I did for bottom of the house but just applied it with a rag and wiped excess off as i went. Missus oiled the cladding while I was at work. Then re-oiled the rest of the house for the last time.. I guess it's pretty obvious that I like mac.......
  5. On with the last bit.. I had never been quite sure how I was gonna finish these bits. If I copied the same style as the rest of the house with the capping it meant the capping would have to go all the way round to the front door which wouldn't work with the decking.. And somehow in behind the main steps.. After mulling it over for a few weeks I decided since there was already a board hanging down to within 35mm of the deck (see above) that I would just copy it with the rest.. it may not be legal as you sposed to have 150mm from bottom of cladding to whatever the actual bottom plate and cavity closer are about 250mm from the deck.. looks much neater anyway. Cut a bit of the deck framing to make way for the corner, All the corners are rebated for water. Corner on, Cladding on. Doing it this way meant I had to replace 8 boards, still have a fairly good supply left so it s no biggie. Going to use the old boards for the balustrade..
  6. Did the back two corners, More night time epoxy...... This was the reason I had wanted to do it this way instead of just leaving it capped with the standard 25x150 boards. Because the house wasn't designed with this cladding in mind I had to set the boards out to fit the windows and forget the corners. Down the track I realised I would have to copy what I did around the windows on the corners, butt joining them looked shit which is why I went with the beveled and glued corner. It meant I could just run the cladding out like this. Which looks much better than this. Of no significance, but on one screw, I managed to break the drill bit I was using, on the corner I had to angle the opposing screws up or down away from each other. Got it wrong and snapped the bit, punched it in further then drilled again on a different angle and snapped another bit, at that point I threw the drill and went and had a cup of tea. In the end I snipped the end of a screw and epoxied it in there.. Cunt.... Oh... And being the total muppet that I am I cut both corners without allowing for the 15deg drip edge on the bottom which left both corners 7mm short. I realised this only after I had glued the first corner (goddammit!) so I had to drop them down and cut a packer to go in the top. Second corner worked fine but the opposite corner now has the screw line 7mm lower than the rest... Fucken numptey.
  7. Now I can carry on.. Did the next corner, but first had to pull the temporary balustrade which led to pulling up the temporary plywood decking. Exposing vw parts...... modern day archeology. This "mistake" mac decking had been patiently waiting since 2017. Well seasoned 35x140. Also came up better than I expected. More late night epoxy. That's not me by the way....
  8. There was one small hiccup, went out to fortress to buy some more bronzed ss screws only to find there were non in the country, fuck. Luckily they had some straight ss in stock (phew) Cue alchemy.. What I wanted, What I got, Magic, Produces this, Then this, X2 of these..... Sigh*
  9. Then it was time to finally finish the cladding (only taken 4 years) Started with the easiest bit to see if my technique would work. Literally just a 46deg over bevel with some epoxy glue, clamped, then screwed. Came out better than I expected.. Carry on.
  10. Re-routed the sewer breather, Could just get my grinder in there to spilt the old pipe out (carefully, don't want a blockage) Another thing to tick off the list, need to re-route the down pipes too but need to find the same bends.
  11. Yes, still toiling away.. Had some things going on the last 6 weeks plus some rain days. Feels like some weekends I get fuck all done.. Actually, that's most weekends. Anyway, Got the last bit under the back stairs done a while back, just cleans it all up. Not much to look at. Framed, Luckily my driver just for under the cladding to drill the dowel holes. Would have been a cunt otherwise. So that really does make the bottom finished. Thank fuck.
  12. I'm hanging for another ferrymead pest.. Train spec.
  13. Exciting.......
  14. I was gonna buy one of those modern cheapish vices but I then went to the vcc swap meet and found a hercules #5 for 70 bucks. It's been very well used and I've given it a beating but still it lives on. Get an old one if you can.
  15. We did start getting letters from the supplier once I started closing everything in.
  16. Yeah, although any escaped gas has been free to wander for the last 4 years..
  17. You've got no idea who's been tightening shit over the years.. Got this Italian bloke who works for us and he fucken overtightens everything all the time. Its like he has to prove he can get it tighter than anyone else. Maybe the previous owner had small man syndrome.. or he was italian, maybe both, they seem to go hand in hand.
  18. Jesus...
  19. Yeah as above I was also about to say. The grooves were originally used down so the timber could breathe and didn't rot between the connections. Somewhere along the line some suit decided it was good for grip and is now policy to have it up. From my experience it can be fucken dangerous when wet with less surface area for your shoe to grip, especially when in a shaded spot. Hardwood is even worse and on some jobs we've had to put put sand down to make it safe (while we're there anyway). We used antislip tape along the front edge of any steps when we built our deck, mainly for oldies.
  20. I was thinking more like putting one in those paint mixing machines they have at bunnings/miter 10.
  21. Wouldn't fairly severe vibration work too? Or more ultrasonic spec.
  22. One day in the near future you can count me in....
  23. The amount of times I've spent hours making shit only to realise it won't work...
