Hey team,
I'd like to order a rebuild kit for this 4bbl, but I'm not sure what it is.
Its on a 390FE on a 67 Galaxie, but the VIN decodes to a 2V engine, which would have had a 2bbl carb, so its not original.
Any ideas? Or know where some identifying numbers might be on it?
Not exactly the same I know,  but the four flutes on the casting closest to the bottom of the photo  and the single tube just above that casting says Holley... and not Edelbrock
Thats a holley
have a look at the front of the choke horn,  there should be a list number which you can look up and it will tell you what it is
14 hours ago, cletus said:
Thats a holley
sweet!
will see if I can find a kit for it
Think that's same as mine. 600 vac sec Holley. Number looks familiar.
Lots of parts/kits available. Think they have fixed secondaries via metering plate? but you can get a jet conversion. Also offer variable vacuum secondary springs so you can tune when they come in. I put a quick change diaphragm adapter on so was easy to play with.
Sort of jealous. Looks fun...
yep that is a 600cfm as already mentioned.   1850-4   the last 4 numbers 2612 are the date code of manufacture, its a cluster to work that one out LOL.  but a great carb, parts are a plenty.
the orings for the tube that go between bowls are a bit tricky so dont pull apart till you have a kit or prepared to wait, unless you know they arent old and hard.
