Does anyone know where the headlight (dimmer?) relay is on a 2001 Fielder? Got me absolutely buggered. Headlights both gone out (high beam work if you hold stalk in, factory spot lights and park lights work) at the same time, new bulbs, checked all fuses under bonnet and up under glove box, also checked all the relays I could find (engine bay, behind glove and one on drivers side behind coin tray) even though all are labelled for other shit.... arrrggg getting to work is sketchy with high beam and spot lights. Assume its the relay but cant find it to save my life.
Isn't it a common problem for this era Corolla to have a failed headlight stalk?
/had similar symptom on my brother's ute, turns out just both of the bulbs had burnt out their low beam at the same time
I thought stalk too. So much stuff going on in there, so much dust & fluff gets in there too.
I had a Marina with that simple BL indicator/ flash/ horn setup and it was so filthy that when you flashed the main beams while the lights were on, the engine started missing.
/ yes, I know. Marina. But the point is a valid one.
  • Haha 2
Im not 100% sure how accurate this is for a fielder, but i think they're just a long body Corolla of the time. I harvested this from Haynes.
Yeah pretty sure you guys are onto it, found a youtube that suggests the relay is built into the stalk (good one Toyota)
