M.H. Posted October 11, 2019 Posted October 11, 2019 Trying to find some new lsd clutches for my Isuzu. New genuine set is $500+ which is a bit more than I want to spend. From looking at pics they look the same as r200 ones but cant find any dimensions for them. Does anyone know if there are any other diffs with clutches like these. Also what break away torque should I be aiming for? Quote
UTERUS Posted October 11, 2019 Posted October 11, 2019 If you do any sort of off roading, you want it fucking tight. Quote
M.H. Posted October 11, 2019 Author Posted October 11, 2019 19 minutes ago, UTERUS said: If you do any sort of off roading, you want it fucking tight. How many nm breakaway is that? 2 Quote
M.H. Posted October 11, 2019 Author Posted October 11, 2019 Just now, cletus said: American spec Isuzu had a GM sourced 10 bolt diff, mine is a jap built one with an isuzu diff so rock auto dont have parts Quote
smokin'joe Posted October 11, 2019 Posted October 11, 2019 22 minutes ago, 00quattro00 said: American spec Isuzu had a GM sourced 10 bolt diff, mine is a jap built one with an isuzu diff so rock auto dont have parts any chance bighorn or isuzu ute use same clutch pack ? Quote
M.H. Posted October 11, 2019 Author Posted October 11, 2019 1 minute ago, smokin'joe said: any chance bighorn or isuzu ute use same clutch pack ? Yea they had the isuzu jap spec diff Quote
smokin'joe Posted October 11, 2019 Posted October 11, 2019 5 minutes ago, 00quattro00 said: Yea they had the isuzu jap spec diff ok. plenty dead in paddocks from fuckwits towing without external trans cooler Quote
Unclejake Posted October 11, 2019 Posted October 11, 2019 Did you check the Motive Gear catalouge? They have a HUGE list of clutch packs, and they're pretty cheap... but they are a US based company so perhaps of no use to you EDIT: Sorry. I was mistaken. Their list isn't a big one at all. Quote
Muncie Posted October 12, 2019 Posted October 12, 2019 Ignore me..... unless you only drive this offroad. Quote
Testament Posted October 23, 2019 Posted October 23, 2019 some isuzus run a Dana 44 of some description too. need to identify exactly what diff you have plus what ratio, as some diffs have different carriers for different ratios too. then you can probably find parts online/ebay/rockauto/etc/etc/match something up. diffs are something where most manufacturers do not reinvent the wheel very often so usually alot of interchangeability/they use someones elses design heaps. Quote
