~Slideways~ Posted February 1, 2018 Share Posted February 1, 2018 My 32 year old corolla has been sitting unused for 12 years or so, I recently did a bunch of work on it to get it back on the road. The electric windows worked last I used it, sluggishly, but they did work. Now they don't, neither the drivers main switch or the passengers. Strangely I can't see a fuse or relay, I didn't have much time to investigate (because tiny humans) but I assumed it would be in the kick panel fuse panel or the under bonnet fuse box. Can anyone tell me where to look before I write a strongly worded letter to Toyota demanding a recall? Is it a shared power source/fuse? Is there a control box or relay hidden behind the kick panel maybe? I'm asking Oldschool because the limited amount of garage time I have these days must be for race car finishing, else I will lose my mind. Thanks Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 1, 2018 Share Posted February 1, 2018 If they were sluggish before, I would first try and pull the door cards off and clean all the old, rooted grease out of the mechanisms and put new stuff in. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 1, 2018 Share Posted February 1, 2018 Its fucked mate pay me a hunnit and ill take it off your hands Quote Link to comment Share on other sites More sharing options...
Ranter Posted February 1, 2018 Share Posted February 1, 2018 I'd remove the door panel and power up the motor to check, sounds like a switch issue. Passengers won't work if master switch is faulty. Not sure on that particular car but I've never been as lucky as a fuse or relay fix for windows. Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted February 1, 2018 Author Share Posted February 1, 2018 12 hours ago, xsspeed said: Its fucked mate pay me a hunnit and ill take it off your hands Your mum. Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted February 1, 2018 Author Share Posted February 1, 2018 1 hour ago, Ranter said: I'd remove the door panel and power up the motor to check, sounds like a switch issue. Passengers won't work if master switch is faulty. Not sure on that particular car but I've never been as lucky as a fuse or relay fix for windows. Good idea, will try this. Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted February 1, 2018 Author Share Posted February 1, 2018 17 hours ago, ajg193 said: If they were sluggish before, I would first try and pull the door cards off and clean all the old, rooted grease out of the mechanisms and put new stuff in. I assumed it was the motors getting old but it might help, thanks for the suggestion. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 1, 2018 Share Posted February 1, 2018 had near identical issue with the ones in my pos racecivic, turned out they were earthed to a point in the drivers kick panel area and there was a loose bolt, they went from very slow (poor earth) to not working (no earth). tightened up earth bolt and good to go. Could be worth checking, I had assumed they would have been earthed on brackets in the doors but that was not the case. 1 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted February 8, 2018 Share Posted February 8, 2018 If all else fails i think I have a pair of electric mechanisms here for a ae82 fxgt Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted February 8, 2018 Author Share Posted February 8, 2018 17 hours ago, Toddy415 said: If all else fails i think I have a pair of electric mechanisms here for a ae82 fxgt Cool, I'm still waiting for it to come back from the wof so I haven't been able to test anything. But thanks for the offer, I'll see what I find. 1 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted February 8, 2018 Share Posted February 8, 2018 Yea doesn't sound like the motors since both have stopped but you never know. 1 Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted February 14, 2018 Share Posted February 14, 2018 Would almost put money on the switches being scummy on contacts. Strip em and clean em and see how they behave. 2 Quote Link to comment Share on other sites More sharing options...
