Electroplating
MKD
I'm looking to electroplate a few bike frames DIY - but questions regarding removing the exisitng paint:
whats the best paint removal method for a smooth steel finish on the frame? i've sandblasted a few frames in the past, but im not sure if the plating will look as good on the matte blasted finish compared to the powdercoat that has been done on my previous blasted frames.
so for best and most complete paint removal do i use - paint stripper? wire wheel? sandblast? a combo?
For not touching the metal surface I've had good results with paint stripper. You want to hang the frame up and shower it in really nasty, and I mean knock out an elephant with a wiff nasty, paint stripper. Coopers works well. Then water blast off after leaving it to sit for a bit. Scotch bright can be used to polish up the metal surface a bit
