SOHC Posted June 23, 2016 Posted June 23, 2016 My 1981 Volvo has had a bad thread on #no3 since I have owned it but now it has started chuffing can someone recommend someone or could I borrow / hire a repair kit? Quote
tortron Posted June 24, 2016 Posted June 24, 2016 How bad is the chuffing? A little is normal because plugs don't seal off the thread, they seal off the washer Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 How bad is the chuffing? A little is normal because plugs don't seal off the thread, they seal off the washer Its the lack of thread that is causing the plug to just wobble round in the hole and not tighten, its very bad. Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 I have rung all the pars places and they don't sell any form of thread repair kit . I have been looking on the internet and there are some very good loking kits called sleeve repair kits where the cutter has a spigot to help get it straight and then you use the sparkplug to wind in the insert. I bet there is no hope of getting one in this shitty old town? Quote
Borgweiser Posted June 24, 2016 Posted June 24, 2016 Dude, save your self a load of grief and drive it into Taylor Automotive. They're not the cheapest but they do this all the time, will be bout the same price as a kit and they will wind in a solid coil or such with the head still in place. Unless someone knows another good engine reconditioner locally? I used to use Taylors when I was spannering Jags in Auck several years ago. 1 Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 Not going to Taylor Automotive had a bad experience twice 1 Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 They sell kits like this everywhere apart from NZ 3 Quote
flyingbrick Posted June 24, 2016 Posted June 24, 2016 25 Piece Spark Plug Thread Repair Kit M14 x 1.25 http://s.aliexpress.com/2qM7bIjY (from AliExpress Android) They have Ali express in nz! 1 Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 25 Piece Spark Plug Thread Repair Kit M14 x 1.25 http://s.aliexpress.com/2qM7bIjY (from AliExpress Android) They have Ali express in nz! Inserts aren't long enough Quote
Muncie Posted June 24, 2016 Posted June 24, 2016 I had all the spark plugs helicoiled on my gsxr 250 15 years ago by panmure motorcycles. head stayed on and its still going i know its a bike shop but they're work has stood test of time for me a car would be 20x easier than my bike was, worth a try bet they would do it. 2 Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 I had all the spark plugs helicoiled on my gsxr 250 15 years ago by panmure motorcycles. head stayed on and its still going i know its a bike shop but they're work has stood test of time for me a car would be 20x easier than my bike was, worth a try bet they would do it. I know Lorrie well. Problem is I would need to remove the booster and master cylinder and there is no way to get a drill in there as the plugs are on a 45 angle and they all face back, thats why I wanted the kit that didn't have the tab and didn't need a drill. The GSXR they are easyer to get at apart from they are deep down inside the head between the cams Quote
Muncie Posted June 24, 2016 Posted June 24, 2016 I see your point that sounds like a cunt of a job. Theres someone out there that does these bastard jobs for a living just gotta ring around. Quote
SOHC Posted June 24, 2016 Author Posted June 24, 2016 I warped tinfoil round the plug and screwed it in and it seems to be pretty tight and should last a wile I hope 6 Quote
SOHC Posted June 25, 2016 Author Posted June 25, 2016 Next time I get some new plugs I will squeeze one a bit in the vice and crank it in. I was trained by professionals in the old country 4 Quote
SOHC Posted June 25, 2016 Author Posted June 25, 2016 Tin foil with locktight on the outside. I don't think it needs locktite, it seems good Quote
flyingbrick Posted June 25, 2016 Posted June 25, 2016 Lol. Spark plug thread repair kit. Rrp $49.99 Contents: 1x foil square. 6 Quote
tortron Posted June 25, 2016 Posted June 25, 2016 Used to have to wrap hemp twine around the threads in old flatheads 3 Quote
tortron Posted June 25, 2016 Posted June 25, 2016 Is the head cast iron or aluminum? Could you braze it up and run a thread cleaner down it. Might be enough if it's tinfoil bad 1 Quote
