  • Replies 48
Now I know for sure the dizzy won't fit it's gonna be full standalone
Later model 626 has 36-1 trigger wheel front pulley
Get to ditch the maf too and just run crank trigger tps and map sensor
Spent half the day marking drilling and cutting excess off the 12mm steel adaptor plate the local engineers roughcut for me cheap
4kg untrimmed prob get it down to 2kg by the time it's finished
Lost so much weight off the car by removing AC and power steer
Steel worked out cheaper easier and stronger for the threads I need to tap into it
Crap photos of progress sometime soon
Much cutting grinding hacksawing grinding and drilling and tapping later
12mm holes thru to block need countersunk for flat countersunk allen screws - one main bolt shown goes right thru bellhousing to block - that and the input shaft into spigot what i have lined it all up on
Threads tapped 10mm for bellhousing to adaptor bolts - still needs more trimmed off this side - hole visible was a tester for drill and tap sizing
Eyeometry and sheer luck mostly
Motor sitting on it's nose so no load any direction
Rx7 bell is shorter than mx5 so the input shaft pokes out about 12mm
Already knew one bolt hole lined up to the motor from yoeddys viva build
So drop box onto adaptor and into spigot drop bolt in - wiggle the box so there is no side loading - check input shaft turns freely
Clamp down mark and drill other bell housing bolt holes
Adaptor plate sits over motor dowels
Have a couple of blind holes in bell so I will add dowels to adaptor too
Backwoods bastard bodging really but workin with what I have access to here in the Styx
Yup spigot bearing is farked but still turns and
Whole clutch kit is on the way so I can get that buttoned up and start on engine mounts and chopping up the sump
Intake manifold ideas are now making my head hurt
Slow progress
Picked up another v6 cheap for bits looks clean has plenty of parts for spares as i experiment with bodging
Visited Alex and Hannah and looked at their awesome shed and mighty v6 viva for inspiration
Countersunk the holes for adaptor to engine bolts csk allen screws in m12x1.5 are not cheap
Shoulda not drilled the 2 bottom holes so much and tapped them for for stock bolts thru from the front woulda saved $
Cheap tardme countersink bits were great cut mild steel so clean and easy
cut a slice off the starter motor mounting to get it to match up to flywheel - dont grind alloy at home kids its dangerous
ended up being a nogo on using rx7 starter - pinion way too small to match up so its steel plate for here and use the v6 starter
even bought a new rx7 starter too keen ... 1 step forward 2 steps back
started looking at hose routing lost most of the ugly mass of hoses off the v6
lower rad hose routes to rear of block in the valley
flipped the thermostat housing to route heater hoses towards car heater and lower rad hose to drivers side where mx5 rad inlet is
removed a big ugly hose tee and blocked it with a frost plug
These look like a much easier way about it than the usual Triumph speed triple TBs used by others. I'm watching this with interest!
Its gonna sound great!!!!!
More slow slow progress
Trimmed the adaptor plate down to final size (2.5kg) and painted it to stop rust and pretend its alloy
Started making the starter motor plate
Chopped up a sump to start on making one of those to fit
Manual steering rack arrived and gasket set and 36-1 crank pulley on their way cheap via Amazon and Youshop
Got inlet manifolds back from local alloy wizards
Machined the manifolds short as possible and flat
Sized alloy tubing to squash to oval to match the inlet ports
Squashed cut welded
Needs just a bit of trim to level up the top ends and  dremel porting to smooth it in for flow
And this shows how much room i dont have to make an airbox ...
Yeah that aint a lot of room. The idea I had for what I was thinking of making for you was a tapered plenum, sloping down towards the front and then have a 90 degree bend into the back from the TB.
But I'm still full on building a food cart plus making a custom refridgerated display unit.  Luckily looks like you are sorted now :-)
Getting there...
Just sorting linkages and the alloy braces between bodies today
I have jigsawed a curve in my wooden bonnet guide now so a little more room
Thinkin just an alloy box for air intake with two hoses running to pods behind each headlight for cold air feed
Can get lower without those rubber BMW joiners on top too
Very tight clearance between the back itbs and the throttle arms
And the whole v6 everything is staggered is interesting to work around
  • 3 months later...
Yep seen that almost bought a jag/aj/ford Mazda v6 before I scored the cronos
Most seem to think the kl is the better engine but they do build the noble sports cars with those mondeo v6s
Updates yeah well been working long hours 6 days a week
Scored some new wheels and some new adjustie spensions so that has eaten into build funds
Engine mounts are half done want to finalise the sump/oil pickup for clearance before I finish the mounts
Having the engine sitting in the car and a spare engine on the stand is making it easier to do wee bits and pieces
Throttle links and water and oil plumbing slowly getting sorted as Alislowexpress bits arrive
